Caliper Piston "tricks" Anyone?
Old Jul 6, 2005 | 06:25 AM
1995WhiteMaxima's Avatar
I'm gonna replace my brake pads again, and I already anticipate having issues getting the caliper pistons compressed into place. I bought the caliper tool and also tried to use the needle nose pliers as an alternative but ofcourse only one piston budged. I was forced to replace the other entire caliper in a loss to dirt, rust and grime. I sprayed on a ton of lubricant with no success, which probably wasn't such a good idea because it probably destroyed the seal. Anyone know of a trick that I haven't tried?
Thanks.
Old Jul 6, 2005 | 06:29 AM
hollaatchaboi's Avatar
Are you talking about the front or back? Well what i do is i remove the cap from the master cylinder so its a little easier for the pressure to go back. For the front, I usually use a rock and a c clamp. For the back, i just take some pliers and start twisting. Its tedious, but it works.
Old Jul 6, 2005 | 06:31 AM
Bobo's Avatar
You are turning the piston clockwise I trust. I just replaced both rear calipers and brake pads about two months ago on my 95SE because the right rear was frozen. If you have to replace your rear calipers, ensure you replace both and not just one as brakes are hydraulic and you will have uneven brake application, in all likelihood, unless both calipers are replaced at the same time (or so I've been told).
My right rear caliper froze because I hadn't use the parking brake much in about 6 years.
Old Jul 6, 2005 | 06:36 AM
njmodi's Avatar
Do I get a tax break?
Nope - you've got the bases covered. If the piston doesn't retract fairly easily with the piston tool (turning clockwise), then you have a seized piston and its probably time for new calipers. As already mentioned, be sure to either loosen the bleeder screw (and then subsequently bleed the brakes) or undo the master cylinder reservoir cap before trying to retract the pistons back into the caliper.
Old Jul 6, 2005 | 06:47 AM
Rock and C-clamp?
How do you use a c-clamp on the fronts? I thought we could only screw the piston back in. If I could use a C-clamp that would be a big bonus.
I guess when I do the rears and I find I need to replace calipers I'll replace both- hopefully it won't come down to that.
Old Jul 6, 2005 | 06:48 AM
njmodi's Avatar
Go through the how-to at www.motorvate.ca and you'll have everything you need to know.
Old Jul 6, 2005 | 07:03 AM
maxlauj95's Avatar
Well my 95 front use C-Clamp and rear used caliper tools..which u can pick up at AZ or advance auto for like 10 bucks....also the link njmodi provides is very helpful. I did mine like a couple weeks ago.
Apr 16, 2020 05:15 AM
6spd4dsc
Mar 4, 2016 05:19 PM
imported_Nismo_max
Sep 21, 2015 07:24 PM
bbsitum
Sep 11, 2015 04:55 PM
beerman1378
Sep 8, 2015 02:19 PM
