auto start for MANUAL SHIFT
Old May 21, 2001 | 09:04 AM
Vinipux's Avatar
hey guys, I just purchased an auto start kit for my manual car, now, the kit is suppose to work with my original oem remote, so I can get any button to do the work, I will probably use the "light" button, since it's there for nothing
my question is, whether any of you have done this, and if you have, anything I need to look for, be careful about... you know, the little stuff that I should know
now, I was thinking, obviously I'm going to disconect the clutch thingy, and to make sure that it doesn't **** up, install a switch so if the car is in a gear, it would have a forced ignition cut, so the car doesn't role, that would be bad
thanks a ahead for the advice
Konstantin
Old May 21, 2001 | 10:24 AM
dmbrazilian's Avatar
Well thats actually a panic button...thats if the 95 remotes are the same as the 97's....but it should work as long as you disable it..
Konstantin
Old May 21, 2001 | 10:26 AM
Sonic's Avatar
You hold down the lock button to use the panic feature, not the light button.
Old May 21, 2001 | 12:01 PM
I guess that is on the 95 models then....cause my 97 the panic button is the the "panic" button.
Old May 21, 2001 | 12:26 PM
Vinipux's Avatar
95 model
well, I actually have a infinity remote, but it's the same as the 95 model, the "panic" button has a picture of a light on it, when you press it, the interior lights go on, but if you hold it for like 3 seconds, the panic siren starts. so that's why I was saying that I should use that, because I would still be able to use the panic thingy, not that I would ever want too
Konstantin
Old May 22, 2001 | 09:20 AM
Max4Speed's Avatar
www.autotalk.com
Yea i have remort start but i didnt put JUST the remort start. i went with the whole DEI-6500(Sidewinder) and i dont use the factory remotes no more. they stil work if i use em,.. i dont have no switch for my clutch(it is manual ofcourse) but make a habit, NEVER leave ur car in gear! I left it once.. nothin really happens as long as u got the hand brake on. plus in my thing, i have to press 2 button at the same time to start it, so it is not that dangerous and if i press em second time then it will stop the car.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Matt93SE
May 24, 2019 02:58 PM
Cotozic
Jun 28, 2017 08:01 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
Trin1j23
Aug 12, 2015 08:31 PM
