[B]Car sounds like a deisel engine upon idle[/B]
Old Jul 8, 2005 | 04:15 PM
mbb6's Avatar
heavy heavy vibrating, like a muscle car, mechanic said that there may be a short in the wiring harness leading to the 2nd injector, how would I trouble shoot this problem, figured follow the wiring from harness, this may be an ecu problem as well. not sure. helpcar sounds like a deisel engine upon idle
Old Jul 8, 2005 | 04:44 PM
njmaxseltd's Avatar
Is the check engine light on? If so, check to see what code might be present.
When's the last time you changed or checked your oil level?
A defective timing chain tensioner can cause excessive chain slack which sounds horrable as well.
Old Jul 8, 2005 | 08:26 PM
mbb6's Avatar
could this be a result having too much oil, will get an oil change tomorrow to isolate that problem. the codes are knock sensor, and intake air temp malfunction, i am running a short ram intake so the intake code has been present. may try changing the knock sensor.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
