do i need alginment after putting on rims?
Old Jul 13, 2005 | 06:55 PM
VIP Maxima
would i need an alignment after i put on some 19x8's?? im gettin bigger tires than what is recommended (increasing diamater), dunno if that matters !
also, what locking lug nutz do u guys recommend??? i know they are useless but wth, at least it slows them down !
Old Jul 13, 2005 | 06:58 PM
MaximaPWR
no, what makes you think you would?
as to lug nuts...only McGuard or McGard (forgot which one)
They are expensive - paid $65 for all 20, but well worth it - none of this POS-rust-in-3-months Autozone BS.
Anyway, I've had them on for close to 2 years with no sign of rust whatsoever. They are a perfect fit, even on your stock wrench.
Old Jul 13, 2005 | 06:59 PM
VIP Maxima
i remember somebody saying that "alignment is required whenever u touch suspension" !
Old Jul 13, 2005 | 07:03 PM
njmodi's Avatar
Do I get a tax break?
Not sure if going with a drastically different overall circumference is a good idea.
Bonka's Avatar
Schnell kaputt
You're not touching the suspension.
I recommend Gorilla lugs...the name should scare would-be thieves off
MaximaPWR
here you go, you won't be disappointed:
http://www.mcgard.com/search/default...vID=1&NavID=11
don't remember what size we have, bc I bought them 2 years ago
Old Jul 13, 2005 | 07:04 PM
VIP Maxima
its only 245/40 lol, nothing too crazy !
Old Jul 13, 2005 | 08:01 PM
RicoSuave98's Avatar
probably ought to get it aligned- it couldnt hurt
and you might want to check this out for lug nutZ
Old Jul 13, 2005 | 08:35 PM
G4nismo's Avatar
well u don't wanna f up one of tires do u?
Old Jul 13, 2005 | 08:37 PM
Loe max's Avatar
If your alignment was good before, you shouldn't have to do more than a tire balance.
VIP Maxima
the thing is im putting on the rims like 4 days after i lower the car. was just wondering if i should do alignment right after i lower it or wait for the rims then do the whole thing ?! in another words, the car will be already newly aligned when i put on the wheels if i choose to do it right after i lower it.
Old Jul 13, 2005 | 08:41 PM
G4nismo's Avatar
gotcha^^^^^^
what rims u getten?
Old Jul 13, 2005 | 08:42 PM
Fr33way™'s Avatar
Wild for Width
I would do it with the new rims. Why not do it with the setup you are gunna be running? (the 19s after drop)
Old Jul 13, 2005 | 08:47 PM
VIP Maxima
gotcha^^^^^^
what rims u getten?
no real reason, other than to save my time. also i wanna avoid taking off the rims one more time and putting them on. they might scratch it blah blah !! shops are careless !
my current alignment is horrible. i hit a curb few months ago, popped 2 tires, bent my stock rim a little bit and i have horrible shakes @ 70-80 mph. aslo, front 2 tires are bald as heck
Old Jul 13, 2005 | 09:18 PM
DennisMik's Avatar
hey guys- you change tire size and you need an alignment - but not to factory specs. you have to calculate new specs for at least the caster so the edge of the tire doesn't wear out. a bigger circumference tire would wear on the outside edge without calculating new alignment specs. and then there is always the big tire rubs on something when you make a sharp turn.
also, if you change the diameter of the tire, the speedometer will be off. larger diameter tire means the speedometer reads slow.
Old Jul 13, 2005 | 09:49 PM
SpeedyMaxima's Avatar
Lol mike my favorite rims EVO's im in love with them
Old Jul 13, 2005 | 11:22 PM
ImmaSquashYou's Avatar
well, getting an alignment is good. but you have to be careful of where you go. i went on tues to firestone to try and get a lifetime warranty on the alignment, everything was fine, except i noticed since my car is so low, it wouldn't of gone up the ramp. so....yea, gotta be careful with that, dun wanan go through the hassle n then realize they can't do a thing because they can't get your car on the lift. Motegi lug nuts are cheap, nice, n are good.
Old Jul 14, 2005 | 12:00 AM
VIP Maxima
they arent evo's lol. they are EV-S's
Old Jul 14, 2005 | 05:56 AM
Loe max's Avatar
Wait until you lower the car
Old Jul 14, 2005 | 08:46 AM
MDeezy's Avatar
lower and put rims on get alignment. If anything stand and watch them so they'll have to be careful. A scatch or two is better than having to buy a new tire (thats only assuming they cause a scartch)
Old Jul 14, 2005 | 09:16 AM
kosmo886's Avatar
it couldnt hurt to get it aligned
alahjahwan09
18
Sep 21, 2015 09:12 PM
Krazzespiinz
Sep 13, 2015 07:10 AM
0m3nc0w
Sep 11, 2015 05:21 PM
Maxima.KsA
Sep 8, 2015 11:33 PM
adamgalazka
Sep 8, 2015 01:27 PM
