Need help removing dash..
Old Jul 14, 2005 | 12:02 AM
tavarish's Avatar
fwd gone rwd cr00
Hey, I'm removing the black dash in my '95 GXE parts car, and I've taken off all the bolts and screws, but it still seems to be stuck on something. I looked underneath where the airbag sits, and it looks like that is still connected, but the airbag is connected with a weird star shaped circular bolt. what kind of tool would i need to remove the passenger airbag to remove the dash, or can i remove it as one piece?
Thanks,
-freddy
Old Jul 14, 2005 | 12:19 AM
Maxima_Joe's Avatar
4th Gen Parts King
Youu need a tamper proof t45 torx bit to remove the airbag. It can be bought at any local parts store. Or you could remove 4 10mm bolts that secure the airbag to the dash but it is a very tight fit for those bolts. It would be much easier to buy the torx bit.Also remember to remove the battery ground for atleast ten minutes before unplugging the airbag. Did you also get the bolts under the defrost vents next to the windshield?
Old Jul 14, 2005 | 12:23 AM
tavarish's Avatar
fwd gone rwd cr00
yup...i got the 2 bolts in the vents...thanks for the help...i'll buy the bit tomorrow.
Old Jul 14, 2005 | 12:29 AM
TJ_Max's Avatar
Paradox Systems Vendor
was this a long process for you? im thinking of doing this to paint my dash....
Old Jul 14, 2005 | 08:57 AM
tavarish's Avatar
fwd gone rwd cr00
not at all...just the airbag's a pain. It'll take you less than an hour.
Old Jul 14, 2005 | 09:08 AM
Chickan's Avatar
I'll second that the airbag is a PIA to get out. I ended up tearing the dash to get to the four 10mm nuts that hold it in place.
Supposedly you can just remove the special tamper proof nuts (I borrowed the tool from a nissan dealer since Autozone looked at me funny, and I even brought a nut in too!), to remove the airbag, but I had no such luck. Just wouldn't buldge.
Old Jul 14, 2005 | 10:55 AM
Perryb's Avatar
does anyone have a diagram of the fuses under the dash i have lost my door somehow and i don't know which fuses are which. please help
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
