quick rim question
Old Jul 17, 2005 | 07:38 PM
9maxima5's Avatar
quick rim question
Guys has anyone put a set of acura 3.2 type s on there max or i30. I am lookin at a set and the bolt patter in 5x114 but the tires are 215/50/R17. Would it fit and if so would it look bad? below is the pics of the wheels.
Old Jul 17, 2005 | 07:42 PM
99Automagic
As long as the bolts fit into the holes, should be fine. The tires are not wide enough to rub so that's ok. I think they look nice. How much you get them for?
Old Jul 17, 2005 | 07:43 PM
Loe max's Avatar
It will be tucked in the fender more so than stock because of its offset.
Old Jul 17, 2005 | 07:47 PM
9maxima5's Avatar
Could this represent a problem for rubbing? thanks for the reply..
Old Jul 17, 2005 | 07:48 PM
9maxima5's Avatar
Didnt get them yet seeing if they would fit first.
Old Jul 17, 2005 | 10:27 PM
maximariceboi's Avatar
yes..the rims would fit...on the other hand..the tires are too small and also the acura's offset is higher than the maximas...wouldnt recommend them but try if you would like
Old Jul 18, 2005 | 05:53 PM
XtinctWS6's Avatar
dont know anything about fitting but they look nice. good luck if they fit
Old Jul 18, 2005 | 05:59 PM
Loe max's Avatar
IIRC these are 45mm offset. If you get them, remember that:
Get spacers to make it look right
The spokes on the rims protrude outwards of the tire so there is a good chance of scraping it
These rims with your average 215/50R17 tires are 49-51lbs
CL-S rims are .5" wider than TL-S rims
Old Jul 18, 2005 | 06:56 PM
z32drifter's Avatar
You might want to check the center hub size on the Acura.... I was told that they are less than 66mm.... so the hub would have to be enlarged to fit on the car. I have not checked personally just passing along info I was told
Old Jul 18, 2005 | 07:00 PM
95maximan's Avatar
look good man, id say get a junked rim and test fit if your seriously considering this...
Old Jul 18, 2005 | 07:56 PM
Loe max's Avatar
It should fit the hub, its just that you can't use the center cap because it gets in the way that it sucks
Old Jul 19, 2005 | 02:20 AM
tonelocnyc's Avatar
hey on the subject of rims..do you guys know if rims from an eclipse would fit a max? tires are 225/40/18 i think. thanks and sorry if i hijacked
Old Jul 19, 2005 | 05:09 AM
ImmaSquashYou's Avatar
i'm running 225/40/18 right now. but be careful i had 2 sets of 18s n 2 sets of 17s. the 18's were alwyas bent. mine is bent right now. but the 17's were fine. the right tire size for our care is 235/40/18 and can still go a lil bigger. difference i believe between the 225/40/18 n 235/40/18 is about .5 inch difference
Old Jul 19, 2005 | 05:30 AM
NookieMax's Avatar
ummmm what...??????????????????
4th gen max's never came with 18" rims
stock sizes are something more like
215/55-16 for the SE and
205/65-15 for GXE
Old Jul 19, 2005 | 05:34 AM
NookieMax's Avatar
by the way, I have these exact size tires and I have nothing close to a rubbing problem.
You def want to check the offset tho, It does look like these rims will sit more inside the well than stock, and you prob won't be able to have center caps
Old Jul 19, 2005 | 06:09 AM
Loe max's Avatar
Using 10mm spacers might allow it to clear the hub in order to use the center cap. These rims IIRC are 45mm offset.
Old Jul 19, 2005 | 08:38 AM
browne's Avatar
what is the offset for oem 16" 5 star rims for 98 maxima se?
Old Jul 19, 2005 | 08:41 AM
MaximaSE96's Avatar
Maxima Owner
who cares about offset just get some spacers to push then out a little bit....but IMO Acura wheels dont belong on a Nissan...if they were Lexus IS300 wheels then i would say ok
Old Jul 19, 2005 | 08:42 AM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
Get 235 R17 /45 or 50 215 will not look good, your rims will stick out more then your tires.
Old Jul 21, 2005 | 06:03 AM
NookieMax's Avatar
I agree, I wouldn't even worry about those acura center caps,
through some nissan ones on there, that would look interesting to anyone who knows better
Mar 12, 2020 12:06 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
Maxima.KsA
Sep 8, 2015 11:33 PM
adamgalazka
Sep 8, 2015 01:27 PM
Johnny9595
Sep 3, 2015 05:18 AM
