P1444 error; please help a non donating member
Old Jul 19, 2005 | 06:01 AM
sharabi's Avatar
I understand there's a search button and is accessible to people who donate. I guess Il do have to since I love the site and SO MUCH HELP FOR FREE!
Anywayz, if anyone of you could PLEASE help me with my questions; Id greatly appreciate it.
My 1998 GXE with 160k has been downshifting REALLY bad lately and sometimes any driving in the city under 40mph is kinda rough.
I got a CEL ; checked the code at autozone and it said :
P1444 auxilary emmision control
On the internet doing a google, it says:
Purge Volume Control Valve or
Canister Purge Volume Control Solenoid Valve
questions:
1. Can someone tell me what this means in brief?
I found this link on google, is it somewhat correct?
http://www.autozone.com/servlet/UiBr...3d801f4e00.jsp
2. How much on a ball park figure will this cost me to fix?
3. Can I do it myself?
4. Can I drive my car for maybe another week or so till I get some $$ or does this need urgent care?
I sincerely appreciate your responses.
Old Jul 19, 2005 | 07:10 AM
sharabi's Avatar
anyone?
Im searchin on google and the sticky on this 4th gen suggests:
CODE : 0214 EVAP CANISTER PURGE VOLUME CONTROL VALVE OR CIRCUIT FAULT.
answer my Q's???
Old Jul 19, 2005 | 07:48 AM
sharabi's Avatar
No help? Well I searched more and got this PDF id like to share wit ya'll.
Hope this helps anyone with codes.
http://carsoft.co.il/my/NISSAN/A32-EC.pdf
ITS THE ENGINE CONTROL SYSTEM of a Maxima.
My problem or if anyone needs help and its possible causes are:
EVAP control system pressure sensor
EVAP cannister purge volume control valve(valve is stuck open)
EVAP canister purge control valve
Hoses(check to see if they are connected correctly)
EVAP canister vent control valve.
Old Jul 19, 2005 | 12:14 PM
97BlackSEGold's Avatar
replied to your pm
Old Nov 29, 2006 | 03:50 PM
kemmo's Avatar
I have had this code (0214 = P1444) problem for two years. Here’s the weird thing - at the beginning the light would go off if my gas tank was less than 1/8 of the tank or if the temperature drops below 40 F. However this year it only goes off if the temperature is low?! I have been trying to fix it and my inspection date is fast approaching - last year I got lucky since the temperatures dropped low enough before my inspection date!
Work done on the car so far: 1) changed evap canister and valve (near gas tank); 2) changed evap canister purge control solenoid valve (under the hood); 3) changed vacuum switch; 4) checked lines for cracks, blockage, properly attached; 5) checked all fuses; 6) even changed the gas cap (the first thing I did)!
Does anyone have any suggestions - you don't know how happy I'll be to finally get this thing fixed...
Apr 16, 2020 05:15 AM
Tmax78
Sep 25, 2015 09:07 PM
junito1
Sep 23, 2015 12:14 PM
Pnjboyzz
Sep 21, 2015 12:41 PM
boomerbrian
Sep 4, 2015 08:25 AM
