AC problem
Old Jul 21, 2005 | 12:27 PM
NCSU_MAX's Avatar
Maximoneypit
AC problem
not sure why the previous thread about this got locked since this is a perfectly legit question but, its 95 degrees outside and i have no AC - havent for the past week trying to figure out what the deal is with it. The fan just does not work - on any speed (does this rule out the resisitor) fuses by the steering wheel are fine and i have all the lights in my centor console. any ideas?
Old Jul 21, 2005 | 01:17 PM
njmodi's Avatar
Do I get a tax break?
The blower motor is probably shot. Its located under on the passenger side, under the glovebox.
Old Jul 21, 2005 | 02:09 PM
NCSU_MAX's Avatar
Maximoneypit
you think thats a junkyard, autozone, or stealership fix?
Old Jul 21, 2005 | 05:01 PM
njmaxseltd's Avatar
Junk yard = Used
AutoZone = Aftermarket (if they even carry that)
Stealership = OEM part, try Pinnacle Nissan on line for a descent price.
Old Jul 21, 2005 | 05:10 PM
DcMaN's Avatar
how hard are they to install? Because mine rattles on every speed except one and doesnt blow out much air.
Old Jul 21, 2005 | 06:34 PM
njmodi's Avatar
Shouldn't be hard to install - a few bolts/screws. I am guessing it would be pretty easy with the glove box off (you might not have a choice). Should be outlined in the Haynes if you have one (hint).
Old Jul 22, 2005 | 12:38 PM
NCSU_MAX's Avatar
Maximoneypit
is there any other possibility that anyone can think of? maybe a relay or something. id rather not buy something I dont need. thanks guys
Old Jul 22, 2005 | 09:38 PM
NCSU_MAX's Avatar
Maximoneypit
bumpity bumpity bumpity.............
Old Jul 23, 2005 | 08:29 AM
NCSU_MAX's Avatar
Maximoneypit
well last nite i discovered something new - when i hit the upper vents button (the one w/ the arrow just pointing at your head) the fan began to blow air out, but only on speed one (even if i turned it to other speeds). then when i changed to both feet and head vents it was like it didnt have enough power to do both and slowly died. what is the deal here?
Old Jul 23, 2005 | 08:37 AM
s0ber's Avatar
Your blower motor is bad, replace it.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
