please help no brake pedal pressure!!!
Old Jul 25, 2005 | 07:31 AM
hash's Avatar
hello just changed all four rotors with new front and rear pads, as well as both rear calipers. I bled the brake line to make sure that the are was all out and the master cylinder resivoir has enough brake fluid in it, BUt when i go to hit the brakes the pedal in almost to the floor for the car to stop.
what can i do to make it normal
thanks hash
Old Jul 25, 2005 | 07:38 AM
maxgtr2000's Avatar
KH3 by popular demand
If the car is running pump the brakes a few times to see if it stiffens up, most vehicles nowadays have a brake booster. If you had a friend to help you have to speed bleed the brakes one at a time, open the nozzle, your friend applies the brake, when the brake is all the way down close the noozle and repeat. Chances are it is not bled properly. Check to see if there are any leaks also because you could be loosing hydraulic pressure.
Old Jul 25, 2005 | 07:41 AM
NmexMAX's Avatar
dot dot dot ...
Sometimes you have to bleed the brakes a few times when you change the calipers. Keep bleeding until there's no air in lines, and there's brake pedal pressure.
Old Jul 25, 2005 | 08:01 AM
hash's Avatar
back to bleeding I go thanks guys really appri/ the help
hash
Old Jul 25, 2005 | 08:06 AM
DcMaN's Avatar
i just did it on mine. Make sure your not leaking any brake fluid, also keep a close eye on the master cylinder reservoir. Cuz if it gets below that you wont be happy. Make sure you also do the bleeding in the correct order. Starting from Passenger REAR to Driver Front to Driver REAR to Front Passenger.
Old Jul 25, 2005 | 08:18 AM
hash's Avatar
ok got it just one prob you mention p/rear to driver front then to passenger rear then to passenger front. what about the driver rear.......
thanks man
Old Jul 25, 2005 | 08:22 AM
DcMaN's Avatar
sorry hehe read the above post now thats correct i made a mistake :P . Also check to make sure that the caliper lines that hold the brake fluid arnt kinked. They should be a nice smooth curve.
aw11power
Oct 10, 2021 04:57 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
salty318
Sep 28, 2015 07:22 PM
Socalstillen
Sep 26, 2015 12:01 PM
