error code Line Pressure Solenoid Valve (Automatic Transmission)
Old Jul 26, 2005 | 08:25 PM
goldtooth's Avatar
Line Pressure Solenoid Valve (Automatic Transmission) 12 05
i checked the ecu faqs, but it said i dont have access to this website.
Can somebody help me on this ?
I dont have any CEL on, but i just checked if theres anything in there. I got 3 codes:
02 05 - Idle Speed Control
03 04 - Knock Sensor
12 05 - Line Pressure Solenoid Valve (Automatic Transmission)
Help PLEASE, THanks.
Old Jul 26, 2005 | 08:53 PM
sonicrunch's Avatar
What is your question?
Old Jul 26, 2005 | 08:54 PM
goldtooth's Avatar
How to fix or get some info on Line Pressure Solenoid Valve (Automatic Transmission) 12 05
Old Jul 26, 2005 | 08:58 PM
DAVE Sz's Avatar
Hooooooonda.....
The pressure solenoid is the drop resistor code. It's located on the driver side strut tower inside the engine bay. It's mounted on the side of the strut tower. If you have the DR mod done that's the problem. If you don't it's either disconnected, shorted or the solenoid is dead.
The idle speed control is probably related to the intake. By your throttle body there should be a few colored connectors(pink, purple), make sure they are plugged in.
Knock sensor is either dead or thrown out cause of the IAC code.
Old Jul 26, 2005 | 09:10 PM
goldtooth's Avatar
ah, ****, noooo, not knock sensor !, thats like $100ish , ****.
I dont have any DR mod, everything is plugged in how it should be.
Old Jul 26, 2005 | 09:49 PM
f550maranello2's Avatar
i just replaced the line pressure solenoid and i dont feel any differece in how the car drives.. my resistor is good .... im gonna check again for codes in the morining
lowpost99
Oct 26, 2025 06:53 PM
mrc00l88
Jan 25, 2024 01:14 PM
CorollaULEV
30
Aug 9, 2021 08:11 PM
mvm062
Nov 30, 2020 09:00 AM
cmpowell86
Aug 10, 2015 12:35 AM
