Need help quick!!!!!!!!!!!!
Old Jul 28, 2005 | 02:29 PM
VQMAX96's Avatar
I got my y-pipe in yesterday, and today i'm installing it. I got all of the bolts off except one. I've sprayed everything I have at it, Wd-40, PV Blaster ect... and it still won't come off. Any tips would be helpful.
Old Jul 28, 2005 | 02:31 PM
Jeff92se's Avatar
I'm needing a caw
Here is a tip. Which bolt is it?
Old Jul 28, 2005 | 02:33 PM
VQMAX96's Avatar
i'll insert a pic... brb
Old Jul 28, 2005 | 02:34 PM
Max_Out's Avatar
Under the radar
i've had the same problem working at the shop. the best thing to get it off is a air chizzel or if you don't have access to a chizzel, a hack saw will do the trick. i know it doesn't sound like the best i know but, just go to a nissan dealership and order a replacement nut and bolt. hope this helps.
Old Jul 28, 2005 | 02:39 PM
Geophrum's Avatar
if you can get it in there a dremmel with a metal cut off wheel.. a hack saw.. a torch.. or a very long braker bar that will either loosen it or brake the bolt
Old Jul 28, 2005 | 02:41 PM
konak85's Avatar
i'm having the same problem too. Mine is where the cat connects to the Y-pipe. i stripped the hell out of the bolt head. i'm thinking of using a mini grinder with a cut-off blade, whatya guys think? How did you guys do it?
Also it doesn't look like there's a nut on the otherside holding the bolt(cant see cause theres a lot of rust around it). if i cut off the head of the bolt should the rest of the bolt come right out?
Old Jul 28, 2005 | 02:43 PM
VQMAX96's Avatar
first section It's the first section the one near the front bumper.
Old Jul 28, 2005 | 02:44 PM
Jeff92se's Avatar
I'm needing a caw
Craftsmen. Grabs rounded bolts/nuts:
Old Jul 28, 2005 | 02:46 PM
Jeff92se's Avatar
I'm needing a caw
Can't see pic. But try using a 3/4" drive socket/breaker bar with a pipe extension. You will either get it off or break the bolt. Either way it's off
Old Jul 28, 2005 | 03:19 PM
VQMAX96's Avatar
Thanks for the help Guys... But I'm gonna go with the chizzle, we have air tools that came with our compresser. I didn't even know we had a chizzle set.
Old Jul 28, 2005 | 03:22 PM
Jeff92se's Avatar
I'm needing a caw
Chizzle for snizzle!
Old Jul 28, 2005 | 03:31 PM
turbo
Heat yo! will come out like a champ!
Old Jul 28, 2005 | 03:59 PM
konak85's Avatar
anyone have answer for this:
"Also it doesn't look like there's a nut on the otherside holding the bolt(cant see cause theres a lot of rust around it). if i cut off the head of the bolt should the rest of the bolt come right out?"
Old Jul 28, 2005 | 10:21 PM
VQMAX96's Avatar
The chizzle worked just fine...y-pipe is on, and no "bees". Kinda like Warpspeed.
Mar 12, 2020 12:06 AM
NewMax03
Oct 7, 2015 08:27 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
