How do i make my auto shift at higher rpms?
Old Jul 28, 2005 | 04:11 PM
white97gxe's Avatar
This probably sounds noob but thats what i am. What mod can i do to make my auto shift at higher rpms short of a tranny swap? I was thinking of super charging but theres no point if its going ot shift at 3k rpms right?
Old Jul 28, 2005 | 04:17 PM
konak85's Avatar
turn off O/D. Put the tranny in "1" until redline, then "2"-redline, then "D"
Old Jul 28, 2005 | 04:22 PM
white97gxe's Avatar
Yeah i thought about that, but i heard its very bad for the tranny.
Old Jul 28, 2005 | 04:31 PM
97BlackSEGold's Avatar
uhhhh.......floor it
killerVQ30DE's Avatar
I have a (snow | auto | power) traction button when I want to be able to ride the gas without it changing up on me .. I can hit the power button .. it holds it gear longer, and lets you take your foot on/off gas and not have it change on you ... (stock on Nissan Cefiro's)
I'm going 5 speed vvvvery soon, so it might be up for sale. All depends if our trans are the same...
Old Jul 28, 2005 | 04:33 PM
ArcticW's Avatar
What is this mod? I didn't see this device on he FAQ's
Old Jul 28, 2005 | 04:34 PM
kosmo886's Avatar
if you floor it it will shift at damn near redline...basically the more gas you give it and harder you accelerate, the higher it will shift at
Old Jul 28, 2005 | 05:17 PM
Supermax95's Avatar
i think if you leave it in 1, and just floor it it will automattically shift for you when it hits redline....atleast thats what my 88 supra turbo did.
Old Jul 28, 2005 | 05:26 PM
MaximaSpd85's Avatar
if u leave it in "1", it wont shift at all, it'll just bang 6800 or so until u let go
Old Jul 28, 2005 | 05:29 PM
Its not a mod as such, I have the JDM Maxima (Cefiro) it comes standard, when I go manual it will be coming out of the car.. I can't see why it won't just plug in .. although I heard something odd like the US autos have some cable system ?!
Power button seems to allow more torque buildup, just feels more gruntty when you gun it
well it ain't a Supra .. leave it in 1st and floor it and you will bounce off the rev limiter and eventually break something. you can of course wind out 1st gear then move shifter to 2nd, then D with O/D off
Old Jul 28, 2005 | 05:31 PM
if u shift make sure u shift around 6000 rpm tho, cuz the time it takes for the shift to actually occur will put u at redline
Old Jul 28, 2005 | 06:16 PM
white97gxe's Avatar
what is this? http://jime.homeip.net/DR%20Mod.html
Old Jul 28, 2005 | 06:27 PM
Tatanko's Avatar
Bacon Lover
Why don't you just read the page? It explains what it is right on the page.
Old Jul 28, 2005 | 06:30 PM
sean05's Avatar
make it shift hard. You really cant make it shift higher then it does besides leaving it in 1st. If you want to go higher thne get an ECU. They can move the rev limiter up high. Good luck
Old Jul 28, 2005 | 06:34 PM
It tells the trans to switch at full line pressure normally IIRC only 80%, is meant to better for you trans under WOT (foot to floor) as it prevents slipping .. but will kill your trans if you don't have a WOT switch .. rumour to change a bit quicker ..
Old Jul 28, 2005 | 06:46 PM
97maximaman's Avatar
Your all thinking way too complex. It's rather simple actually. Just buy a ******* stick in the first place.
Old Jul 28, 2005 | 07:27 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
Just another stupid Response. You don't know your car very well, do you? It is called Nissan Maxima, not Toyota Supra... Why don't you try it before you make post like this? This way everyone knows what you are talking about.
Old Jul 28, 2005 | 08:02 PM
konak85's Avatar
Old Jul 28, 2005 | 08:10 PM
mike96's Avatar
i have an auto and i shift 1st right on the red if you pass it a little your gonna bounce off the rev limiter and 2nd maybe a little bit past red because the gear isnt rising as fast
Old Jul 28, 2005 | 08:28 PM
jaedaliu's Avatar
my mommy's 95 quest has a power button too. I used that over the 4th when we went to Yosemite and had to get up and down the hills. I'm guessing you'd have to wire something into the ECU, or import a cefiro ECU, and then make a button to switch to power mode. (too much work for me)
Old Jul 28, 2005 | 08:45 PM
udienow's Avatar
There is no way to make an auto tranny shift at higher RPM's but manually shifting it using the 1 2 D with o/d OFF. Leaving it in 1 WILL NOT automatically shift to 2. Tho i dont see your problem, banged the auto tranny still shifts at damn close to redline. All these drop resistor mods and all that stuff do nothing as far as actually when the tranny shifts, it just how hard it shifts.
It's not so bad manually shifting your auto as it is downshifting it. All your doing is forcing it to stay in a gear u want, when u change from 1 to 2 it changes gears like it would if u were in drive. Practice manually shifting your auto at lower rpms so u know how it all works as there is a slight delay from when u shift, and when the tranny shifts. If you dont like that, well just floor it, will be close enuff to redline.
And i dont know what u meant by saying its no point to supercharge if its gonne shift at 3k rpms... Well no shiet its not gonne if its not banged.
Old Jul 28, 2005 | 08:52 PM
tavarish's Avatar
fwd gone rwd cr00
no reason to shift at higher rpm's...autos were built for crusing, not racing. Not maximas anyway. If you want to race, get a 5spd.
Leave your foot on the gas, it shifts at 6000, which is fine, the maxima loses power after 5500 rpm's anyway.
Old Jul 28, 2005 | 11:05 PM
99Automagic
The stock ECU does it's job pretty well when it comes to telling the tranny when to shift. Holding a higher rpm longer won't do shat for you unless you have a supporting mod that utilizes it, such as a mevi or a 00vi. The auto tranny shifts when it's supposed to, right when your power band starts to drop.
Old Jul 28, 2005 | 11:21 PM
I reckon it would just be a matter of unplugging your transmission computer and plugging the Cefiro one (which would have matching harness for power switch)
CorollaULEV
30
Aug 9, 2021 08:11 PM
Cotozic
Jun 28, 2017 08:01 PM
Slamrod
Sep 3, 2015 07:38 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
beboski
Aug 16, 2015 05:23 PM
