M/T swap Question
Old Jul 29, 2005 | 05:15 PM
joeeey's Avatar
M/T swap Question
I found the write up on how to swap to a M/T from a A/T. But that using the same generation Maxima's. I was concidering swaping to a 5 gen trans and clutch. Could someone tell me what items I'll need or problems I will run into by using a 5 Gen instead of a 4 Gen. Also I have read that you must swap your ECM and either add or move a wire. I'm not real fimilar with could someone explain? I have a 99 SE auto with traction control and ABS. any help will be great.
Old Jul 29, 2005 | 05:44 PM
d00df00d's Avatar
Old enuf to pick his own gears
I know you will have to use the axles that go with the transmission you're using. Can't tell you for sure about the ECU thing though... My '95 didn't need a M/T ECU when I got my swap, but I dunno if the '99 will be different.
Old Jul 29, 2005 | 06:58 PM
aznsap's Avatar
i just swapped a 5th gen lsd tranny into my 4th gen. it's basically the same as the 4th gen except some parts will not fit. the master cylinder is the same, but the pushrod that goes into the master cylinder is different between 4th and 5th gens. also the clutch pedal assembly is different. i'm not sure about the clutch lines either since i used aftermarket ones but my guess is they should work. i'm not sure about the ecu issue, i've heard that 99's are a weird 4th gen to be messing with, but i got a 5speed ecu for my '95. hope that helps.
Old Jul 30, 2005 | 08:24 AM
oldngivout's Avatar
Willing to learn
I'm not certain, but I don't believe that the 99 ever came with TCS and manual trans. If not, you will certainly lose that feature. The TCS lamp may remain illuminated on the dash to bother you, however.
Old Jul 30, 2005 | 10:42 AM
joeeey's Avatar
Wel I was going to use only the 5 gen transmission & clutch everything else from a 4th Gen.
Oh yeah I forgot about the TCS. Will this be a problem if I keep the TCS along with the new Manual trans???
Please anyone else?? I don't want to even concider doing this if it's not going to work properly with a 99
Old Jul 30, 2005 | 11:02 AM
WielkiWaac's Avatar
MaximaDriver
ask Mike (blackbirdVQ) from 5th gen, he knows everythink
Old Jul 30, 2005 | 12:01 PM
joeeey's Avatar
Will do thanks
Old Jul 30, 2005 | 10:39 PM
SchismistiC's Avatar
hey d00df00d how much did you end up spending in swapping your M/T from A/T because im looking into that. i wanna know how much in total you spent. Cause i have no control over my car since its AUTO Just let me know thanks!
Mar 12, 2020 12:06 AM
t6378tp
Sep 29, 2018 04:27 PM
The Wizard
24
Oct 1, 2015 08:47 PM
I<3 A32's
Sep 10, 2015 11:07 AM
Johnny9595
Sep 3, 2015 05:18 AM
