Help with tires???
Old Jul 31, 2005 | 10:46 AM
maxihari77SE96's Avatar
Help with tires???
Hello,
Just bought 17 x 7.5 rims....
Have installed tokico adjustables with springs ~1.5" drop visible.
What size tires to go with? 235/45-17? or 225/45-17?
Going for wide look with maximum traction.
Notice the 7.5 width of the wheels though.
Also, somebody told me to put 5mm spacers in the back - to fill out the wells. Is that a good thing to do?
Thanks in advance...
Old Jul 31, 2005 | 10:57 AM
Hajime's Avatar
I don't think 17x7.5 will get stack with the spring, so you don't need a wheel spacer for that. Unless you want your car to look even wider.
I have my 350Z wheels and tires on my Max, and it is 235 at the back too. They give me good traction.
So for your 7.5 , i suggest you to put 235 at the front and back.
Old Jul 31, 2005 | 11:02 AM
Wisky97SE's Avatar
235/45/17 , it will be nearly identical to the OEM diatemer so your Speedo will not be off.
Old Aug 4, 2005 | 04:06 PM
that's what I thought too,
but then I heard that 235/45-17 might be too wide on a 7.5 rim...? that 225 is better?
What do you think...?
Does anybody have any issues with a similar setup...?
Old Aug 4, 2005 | 04:18 PM
maximariceboi's Avatar
i have 235/45/17 on my 17x7 =]
Old Aug 4, 2005 | 05:09 PM
ronin22357's Avatar
I would go with the 235's on it. It will fill out the wheel wells better and you will probaly like the ride better. I have 225's on mine right now and I cant wait until these get worn so I can get 235's next time
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
