Size of nut for rotor?
Old Aug 1, 2005 | 02:43 PM
maxima_million's Avatar
I'm changing my brakes and I have everything off, but I don't have the right socket for the nut that holds the rotor on. I looked in the stickies and went to motorvate but still can't find anything.
Thanks in advance!
Old Aug 1, 2005 | 03:28 PM
njmodi's Avatar
Do I get a tax break?
There are no nuts holding the rotor on... assuming you have the caliper off and the torque member off, just give the rotor a few hard whacks with a rubber mallet or piece of 2x4 and it will pop off.
Old Aug 1, 2005 | 06:39 PM
oh $hiet
It's been a long time since I did the brakes. I took the wheel off, loostened the caliper and removed the cotter pin but I thought I had to take that center nut off. So I don't have to take that nut off? Dang - sometimes I feel like I should drink more coffee! Thanks!
Old Aug 1, 2005 | 06:54 PM
matty's Avatar
Originally Posted by maxima_million
oh $hiet
no that will only allow you to remove the driveshaft...
-matt
Old Aug 1, 2005 | 07:04 PM
njmodi's Avatar
And put a new cotter pin back for the axle nut.
Old Aug 2, 2005 | 04:02 PM
redlinemax29's Avatar
My fronts were no problem at all. But the backs were a major pain in the ****. Anyone else have any trouble with the rears the first time..............???
Old Aug 2, 2005 | 04:23 PM
siballiance's Avatar
i had, i have G35 rims, i broke two of the nuts and i bough maxima nuts they are like 1/2 inch smaller then G35 nuts
i can say, it was paintfull 5 hr's of work and still no effect.
and at the end i finally my friend weld it for me... the nuts i mean
Old Aug 2, 2005 | 04:40 PM
i30ds's Avatar
Armed and Dangerous
You can also put a bolt in the one of the two holes on the rotor and as you thread it in the rotor comes off.
Old Aug 2, 2005 | 07:47 PM
JPMax's Avatar
What's next!?..
The rears are not changed as often as the front brakes and rotors. So yes, theres gonna be a ton of rust holding them on.
Just keep whacking it from the back w a big hammer or find a screw that will fit in one of the small holes in front. Screw it in till the rotor pops off.
Old Aug 2, 2005 | 08:30 PM
_ck69_'s Avatar
What size are the bolts that fit into the hole?
Old Aug 3, 2005 | 09:39 AM
twiggy144's Avatar
Front M10 x 1.25
rear M8 x 1.25
Old Aug 3, 2005 | 12:35 PM
AceTKK's Avatar
Originally Posted by twiggy144
Front M10 x 1.25
rear M8 x 1.25
Thanks for the tip!
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
Socalstillen
Sep 26, 2015 12:01 PM
