Where to connect a Vacuum Guage for testing???
Old Aug 3, 2005 | 07:30 AM
BigLou93SE's Avatar
In the haynes manual, it goes through a procedure to check the vacuum pressure in our engines to help diagnose problems. However, the picture that they provide when describing where to hook the guage up to the engine is shown on the 93-94 SOHC engines. So the question is: where to hook up the vacuum guage for testing?
Thanks in advance
Old Aug 3, 2005 | 08:24 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
you can use the brake booster.
Old Aug 3, 2005 | 08:29 AM
PAY_ME96's Avatar
yup.......
Old Aug 3, 2005 | 08:39 AM
I30tMikeD's Avatar
Just pic any larger vacuum hose off the manifold.
Old Aug 3, 2005 | 10:54 AM
BigLou93SE's Avatar
Ok, thanks guys. In the Haynes manual pic, there is a spot on the actual manifold that they connect it at, I didn't know if us 4g's had something like that.
As for the brake booster - Should a T-fitting be used so that the brake booster can be reconnected to run the test, or is it ok just to throw the guage on one end and not reconnect it? (If that is unclear, let me know)
Old Aug 3, 2005 | 07:30 PM
BigLou93SE's Avatar
bump for post 5
Old Aug 4, 2005 | 06:17 AM
BigLou93SE's Avatar
bump again for post 5 :attention
Old Aug 4, 2005 | 06:44 AM
killcrap's Avatar
not necessary for t-gauge unless you are going to drive the car while checking vacuum readings.
Old Aug 4, 2005 | 06:54 AM
BigLou93SE's Avatar
So just hooking up the exposed end of the brake booster to the vacuum gauge will produce an accurate reading? Thanks for the reply.
Old Aug 4, 2005 | 07:30 AM
killcrap's Avatar
Yes Do That
tarun900
19
Dec 20, 2021 06:57 PM
knight_yyz
Nov 1, 2015 01:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
