Failed Emissions ... Pic posted
Old Aug 3, 2005 | 11:26 AM
scrhale's Avatar
http://community.webshots.com/photo/...12537876udIWkZ
WTF I failed emissions over NOx ppm. I have a PR-CAI (Ottoman) and Budget-Y. I pulled the codes ... 0505 so nothing. The dude suggested that the EGR can be clogged. Any recommendations. BTW I have a 95 so they stuck a plug up my car's @$$ on the dyno. Also, is there anyone else in the Cumming/Alpharetta/Suwannee area that recommends a shop I can just take the car to?
Old Aug 3, 2005 | 11:35 AM
njmodi's Avatar
Do I get a tax break?
Did you run the car for a while before going in for the test? like 10-15 miles at good highway speeds?
NOx are typically controlled (lowered) via the EGR (so the guy is right) - you may have a partially clogged EGR system. The fix is to pull the plenum and EGR tube off and clean out the EGR port and tube. Also clean the valve if needed.
If you aren't a DIYer, any competent mechanic should be able to do that for 200 dollars or so (assuming no parts are replaced).
Old Aug 3, 2005 | 11:36 AM
ewuzh's Avatar
Could be a clogged EGR system. Another forum member was having the same problem with a high NOx ppm reading and it ended up being an EGR issue. Try cleaning the vacumn tubes with a rag and clothes hanger.
Old Aug 3, 2005 | 12:42 PM
MDeezy's Avatar
Wow I live in Northern Atlanta and everytime I got an emission test they never took samples from the tail pipe
Which emission shop did you go to?
I'd suggest cleaning the EGR also and seeing if that doesnt help you pass, if you go back to them it shouldnt cost anything to get emission done again.
If all else fails
Auto Mastertech
(770) 513-1122
1786 Lawrenceville Hwy Lawrenceville, GA
it will be about a 30 mins drive but they dont check tail pipe readins. They check for Cel, and gas cap, if thats good, you pass. $25 gone to them for my last emissions and no probs.
Old Aug 3, 2005 | 12:55 PM
scrhale's Avatar
They did the pipe thing because I have a 95 ... you have a 96 so they don't do that to your car.
Old Aug 3, 2005 | 12:56 PM
MDeezy's Avatar
Oh . . . thats why.
Old Aug 3, 2005 | 01:03 PM
scrhale's Avatar
Well I guess I am off to a mechanic then. My regular maintanence is done at a Tire place that also works on transmissions, brakes, AC, and other annoying tuning stuff. I think they should be able to clean simple EGR crap.
OH and my ABS indicator went off. I am willing to bet it is because my rear calipers are seizing.
Old Aug 3, 2005 | 01:05 PM
njmodi's Avatar
seizing caliper's won't set the ABS light. pull the ABS codes - instructions are in the stickies...
Old Aug 3, 2005 | 01:26 PM
Sounbwoy's Avatar
Originally Posted by MDeezy
Oh . . . thats why.
1996 and up- OBDII
Below-OBD
Old Aug 3, 2005 | 01:28 PM
MDeezy's Avatar
you could also make a post in the reginals see if anyone maybe willing to help, I bet they would be much cheaper than any shop. I believe bijan is doing some EGR work to his car. Make a thread could save you a few hundred $
Old Aug 3, 2005 | 01:53 PM
WielkiWaac's Avatar
MaximaDriver
thats suck. i have no cat, y pipe and still pass emission. yaa but i have 99
Old Aug 3, 2005 | 02:03 PM
scrhale's Avatar
Forgive my noobism ... but I searched every sticky for "ABS" and saw nothing about how to pull ABS codes. I know how to pull ECU codes, but it does take a two year old to figure out that they are not related.
Old Aug 3, 2005 | 02:10 PM
njmodi's Avatar
PM me your email address.
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
