What in the world is a Vacuum Cut Bypass Valve?
Old Aug 4, 2005 | 11:32 PM
burgundyblues66's Avatar
So I am driving, and all of the sudden my check engine light comes on. I check it out, and it is code number 1441 which indicates "vacuum cut bypass valve or circuit fault". Does anyone know what this means or what I can do to fix it???
thanks
Old Aug 5, 2005 | 12:11 AM
Tyrexx's Avatar
STICKY
0801
Diagnostic Trouble Code 0801 points to a problem with the Vacuum Cut Valve Bypass Valve. The malfunction is detected when an improper voltage signal is sent to the Engine Control Module through the VCVBV. The possible causes of this problem include a defect with the wiring or electrical connector, or with the valve itself. The VCVBV is located under the car, near the rear left tire. It is near the Evaporative Emission Canister but not mounted directly on it.
The VCVBV is a solenoid-controlled air valve. You may remove it from the vehicle and perform a bench test. There are two air hose nipples on the valve. Fasten a length of clean rubber vacuum tubing to either nipple. Gently blow through the hose. The valve should be closed and it should be difficult or impossible to send air through the valve. Now use a pair of fused test leads to provide 12 volts to the electric connector. The polarity doesn't matter. With the VCVBV solenoid energized the valve should be open and it should be easy to send air through the valve.
Isn't that right in spider vally?
litch
123
Jan 4, 2024 07:01 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
