How do you Program Stock Keyless entry Remote?
Old Aug 8, 2005 | 11:41 AM
Makavelidadon's Avatar
Anyone knows?? Insert the key 6 times then what???
Old Aug 8, 2005 | 11:49 AM
Black Maxima
...then read the Stickies.
Old Aug 8, 2005 | 11:50 AM
Black Maxima
I've bought new keyless entry remotes for my car, how do I program them?
Replacing Remote Controller or Multi-Remote Control Unit (LCU05)
Enter the identity (ID) code manually when:
-remote controller or multi-remote control unit LCU05 is replaced.
-an additional remote controller is activated.
ID Code Entry Procedure
To enter the ID code, follow this procedure.
Entering "Setting mode":
(1) Close and lock all doors.
(2) Insert and remove the key from the ignition more than six times within 10 seconds. (The hazard warning lamp will then flash twice.) At this time, the original ID codes are eliminated.
ID code entry:
(3) Turn ignition key to "ACC" position.
(4) Push lock button on the new remote controller once (for example, if door is locked using the remote controller during this ID code entry enable state, a new ID code can be entered). At this time, the new ID code is entered. (The hazard warning lamp will then flash twice.)
Additional ID code entry
(5) If you need to activate additional remote controllers, unlock the driver's door, then lock again with door lock ****.
(6) Push lock button on the additional new remote controller once.
(7) This ID code entry enable state and setting mode remain until the driver's door is opened.
NOTE
If you need to activate more than two additional new remote controllers, repeat the procedure "Additional ID code entry" for each new remote controller.
If the same ID code that exists in the memory is input, the hazard warning lamps will flash twice but the entry will be ignored.
Entry of maximum four ID codes is allowed and any attempt to enter more will be ignored.
Any ID codes entered after termination of the "setting mode" will not be accepted. Additionally remote control signals will be inhibited when an ID code has not been entered during the "setting" mode.
Linkage: http://home.earthlink.net/~maxfaq/m...ance.htm#Remote
That was right from the FAQs...
Old Aug 8, 2005 | 12:07 PM
chillin014's Avatar
damn dude....
time for some lockage up in this thread
Old Aug 8, 2005 | 12:08 PM
2 Da Max's Avatar
i changed the battery on mine, and it still doesnt work
Old Aug 8, 2005 | 02:26 PM
robsst's Avatar
You don't program the fob.
You program the car to accept the fob's codes.
Old Aug 8, 2005 | 02:28 PM
Black Maxima
Disconnect, the reconnect the plugs on the unit in the trunk.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
jaydot901
Sep 29, 2015 01:18 PM
