H-Tech's with stock suspension????
Old Aug 11, 2005 | 01:25 AM
RicoSuave98's Avatar
from what i've heard Tein S-Tech's will blow the stock suspension, and i was wondering if H-Tech's are the same deal? they lower about 1" up front and 1.5" out back, i think. anyway will i need to upgrade my shocks if i change em up?
im gettin 19s soon and i want my car to have a more agressive stance too
Old Aug 11, 2005 | 03:29 AM
Bonka's Avatar
Schnell kaputt
If you're going to be doing the work yourself (and don't mind the extra work) you could get away with it. Those stock struts should not blow if your roads aren't bad.
Old Aug 11, 2005 | 07:34 AM
Business810's Avatar
If you're doing the work and don't mind upgrading the struts in ~10k miles then go ahead. You can get away with it for a while, I did with Maxspeeds (similar drop) for maybe 12k before the struts blew. However, your handling probably won't be quite as good without the struts, and you will definitely shorten the lifespan of your current struts.
I would vote get a set of struts and do it right the first time, even if they are just GR-2s. I wish I had just done it once and not had to go back and swap in new struts later. It's your car though, and if money is tight you can put it off for a while if you don't mind the labor.
Old Aug 11, 2005 | 10:15 AM
damn, maybe i'll get rims them ride high for a while and then decide on a drop, cuz im still not sure if i want to. thanks guys
Old Aug 11, 2005 | 10:21 AM
A Flood99's Avatar
i believe H-techs lower the front about 1.5" and the rear 1.0"
Old Aug 11, 2005 | 10:22 AM
brooklynK3Y
First... they are "1.6" in Front.. "1.2" in Back.. Like barely two fingers in front(if you got 17's), and can fit 3 fingers perfectly(without a sound system) in the back.
Second, I'm not sure you want to put that heavy pressure of being low and riding on stock struts in the front.. But if you want to take chances.. Go ahead.. But I would get the rims, and just keep saving up and get coilovers.. Because im sure if you dont like how the car looks with 19's after you get a drop, your going to want to buy a next set of springs and struts. Might as well do it right the first time, and buy coilovers
Old Aug 11, 2005 | 10:36 AM
but see slc roads are not all that nice everywhere and there are several places i go a lot that i bottom out on stock suspension, so i want it slammed, but its not going to happen. i'll end up walking half the time.
and my bad about the drops f/r. it was hella late when i started this thread
Old Aug 11, 2005 | 12:21 PM
brooklynK3Y
I mean, if you want the comfort & handling, yeah H-Tech's will do it for you. But on 19's? with stock struts? That may be a pretty rough ride...
Old Aug 11, 2005 | 02:17 PM
NCSU_MAX's Avatar
Maximoneypit
my friend has been running CUT sprints on stock struts for over a year now w/ no problems. im doing the same thing w/ my progess springs until i get coilovers. the ride is great.
i will say that hes got 18s w/ those cut sprints and the ride can be pretty rough sometimes tho.
Old Aug 11, 2005 | 02:27 PM
Gates's Avatar
With H-Techs you should be okay for a little bit, but I'd really recommend doing the struts at the same time. I ran with stock struts and H&R springs for about 6 months and the ride was okay, but got progressively worse. If you're going to get 19s than you are going to lower it eventually. And if you're going to lower it than you're going to get aftermarket struts eventually so I say just do it all at once. If you do the install yourself than you'll save a lot of time and if you don't you'll save a lot of money and time.
aw11power
Oct 10, 2021 04:57 AM
knight_yyz
Nov 1, 2015 01:34 PM
jaydot901
Sep 29, 2015 01:18 PM
