Which fuse for interior door lights?
Old Aug 11, 2005 | 12:32 PM
95GLEPEARL's Avatar
I was wondering if someone could tell me which fuse do the lights on the inside of the doors run from? I checked all of the fuses in the fuse "box" inside the car and didn't find any burnt out, I'm guessing its one of the ones under the hood but I can't for the life of me find out where it is. I have looked through the Haynes manual many many times and have looked over the wiring diagrams for the interior lights and checked the fuses the diagram shows and have found nothing. Any ideas?
Old Aug 11, 2005 | 12:37 PM
njmodi's Avatar
Do I get a tax break?
Is your dimmer switch turned all the way up?
Old Aug 11, 2005 | 12:48 PM
95GLEPEARL's Avatar
No its not the dimmer , I dont think the dimmer controls those lights anyway, they are the lights ON the door panel, the ones that only light up when the door is opened.
Old Aug 11, 2005 | 12:49 PM
njmodi's Avatar
Got it... did you try swapping bulbs (front to rear even might be a quick thing to try if some of them work and others don't).
Old Aug 11, 2005 | 01:33 PM
TJ_Max's Avatar
Paradox Systems Vendor
hey, whats up, its a 7.5 amp fuse at the very very top of the middle row of fuses....its the dome light fuse....same shyt...
Old Aug 11, 2005 | 02:14 PM
Black Maxima
Try different window switches...
Old Aug 11, 2005 | 04:05 PM
bhmax16's Avatar
Even if the fuse doesnt look blown it may still be. I'd stick a new 7.5 amp fuse in there anyway to see if it does the trick
Old Aug 11, 2005 | 07:01 PM
SiCkBLaCKMaX99's Avatar
i have a similair problem except for the fact that only one of my door lights doesnt work and my hazard lights dont work and the hazard light button and rear defrost button dont illuminate when the headlights are turned on??..???
Old Aug 13, 2005 | 06:02 PM
95GLEPEARL's Avatar
Hey thnx to all who chimed in, I will see if replacing that fuse helps I don't think that is the issue because the dome light works ok and so does the map light. I'm thinking there is a relay somewhere that allows those lights to come on only when the door is opened, I may have shorted that out, anyone have any thoughts on that?
ps sickblackmax I think your problem may be fuse #18 all of the center console lights are controled by that fuse.
pss tj max SICK RIDE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I soooooo wanted a black max!!!
Old Aug 18, 2005 | 09:18 AM
4GENmaxCALLDmax's Avatar
My door lights, dome lights, and trunk have stopped working. The fuses appear closed but like someone just mentioned, i will buy more just to see.
Old Aug 18, 2005 | 02:00 PM
TJ_Max's Avatar
good luck and thanks 95glepearl... let us know wut happens...
tsi6001
Oct 3, 2022 10:23 PM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
vrajesh123
Aug 31, 2015 11:00 AM
rbaker100
Aug 28, 2015 08:11 PM
Jeffesernia11
Aug 23, 2015 06:09 PM
