Fakeing the KNOCK sensor
Old Aug 11, 2005 | 01:03 PM
MAXIMASHIFT's Avatar
hey guys i think i am in need of a little help , i have a lot of codes and i think that the Ks is making most of them. so i am trying to fake it out with a 470 ohm resistor (1/2 watt 5% tolerance) is that is on the product. i tryed this but i am still getting the code 0304 KS what am i doing wrong. thanks.
http://image54.webshots.com/154/5/21...2MQmmRi_ph.jpg
Old Aug 11, 2005 | 01:08 PM
njmodi's Avatar
Do I get a tax break?
What are all the codes you are getting?
Old Aug 11, 2005 | 01:15 PM
i am getting 1001, 0401, 0503, 0304,
Old Aug 11, 2005 | 01:18 PM
njmodi's Avatar
0503, 1001 - Front right 02 sensor - Has this been replaced?
0401 - IATS - do you have this connected? Are you using the stock intake?
Until you fix the O2 sensor and IATS sensor codes, don't do anything with the knock sensor.
Old Aug 11, 2005 | 01:23 PM
ok thos where the codes thet i pulled befor i tryed to fake out the KS but i just went up and pulled them i now have 0707 and 0304, but i faked out the ks why am i stiill getting a code. i think that befor the ks was just throwing codes but if i did fake it out why is it still giveing me codes thanks.
Old Aug 11, 2005 | 01:26 PM
the 0707 is ok becasue i took out the 02 sensor in the cat . i put on a hight flow cat and did not have a spot for it , do you think that was cuse a ks code, in the hanes book it tells me that the 0707 code is ok and it will not change fuel to air ratio thanks.
Old Aug 11, 2005 | 01:27 PM
njmodi's Avatar
The 0707 might be triggering the 0304 - even though the KS has been faked out... you need to find a way to fix the 0707 - just plug in an O2 sensor and clamp it to the exhaust or something
Old Aug 11, 2005 | 01:29 PM
if the 02 sensor is not in the pipe well it still work , or not
Old Aug 11, 2005 | 01:43 PM
does the 02 sensor heat up can i put it inside the car thanks ,..
Old Aug 11, 2005 | 01:44 PM
njmodi's Avatar
Yes, and no. They make o2 sensor simulators... you might want to look into that.. .there have been several threads recently - scroll back a few pages and you should find some good info.
Old Aug 11, 2005 | 02:49 PM
i have OBD 1 so they will not work thanks
Old Aug 11, 2005 | 04:10 PM
ok guys i just hooked back up my rear o2 and reset the ecu and
took to for a spin and when i got back i checked and the f#@k KS code was back. thanks. i need help am i using the right resistors??
Old Aug 11, 2005 | 04:18 PM
99Automagic
you said there wasn't a spot for the o2 sensor. How did you hook it back up? Did you stick the old cat back in?
Anyhoo, o2 sensors do trigger the ks code, so do what you have to do to fix the o2 errors first, reset the ecu, then look to see if the ks code comes back.
Old Aug 11, 2005 | 04:29 PM
i hooked it back up and just just zip tied it under the car . i do not have that code right now just the KS help???
my03maxima
Jul 28, 2024 07:40 AM
09maxshawn11
Sep 30, 2015 10:28 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
