Automatic harsh upshifts.
Old Aug 12, 2005 | 08:11 PM
mbandi's Avatar
Da'Burgh, Go Stillers!
Hey guys,
I drove about 350 miles this evening, on the interstate, and noticed that half way through the trip all of the upshifts are very firm. This has never happened before, the shifts are usually much milder than they are now. It feels like the line pressure in the transmission is maxed out. Is there something obvious I should look for? Thanks for the help.
Old Aug 12, 2005 | 09:16 PM
1996blackmax's Avatar
Have you checked your transmission fluid level?
Old Aug 12, 2005 | 09:28 PM
i30SPEED's Avatar
how many miles does ur max have on it??
Old Aug 13, 2005 | 02:43 AM
99Automagic
Hmmm, full line pressure?
Sounds like the drop resistor went bad.
Could be other things but that's my first guess.
Look here to see where the drop resistor is.
http://jime.homeip.net/DR%20Mod.html
Old Aug 13, 2005 | 05:11 AM
njmaxseltd's Avatar
If the drop resistor went, it should immediately throw a code.
Old Aug 13, 2005 | 05:13 AM
99Automagic
My bad. What code is the drop resistor anyways?
Old Aug 13, 2005 | 05:25 AM
njmaxseltd's Avatar
My guess would be 1205 which is line pressure solenoid or circuit fault.
Old Aug 13, 2005 | 06:33 AM
DJItalianICE's Avatar
I think my car shifts hard to be honest with you guys. I drove a Mustang with the 4r70w tranny, and my car feels like a stick shift compared to that crappy auto tranny. It used to take like a second to shift into gears even when flooring it. A shift kit mod easily got you .2 or .3 seconds on the 1/4mi. The Maxima jsut feels more responsive naturally. When you mean hard shift, do you mean it feels like someone is powershifting?
Old Aug 13, 2005 | 06:59 AM
mbandi's Avatar
The fluid level is good, I service the transmission regularly. The car has 187k. I was wondering about the drop resistor but was not sure how to check it. Any idea's on the best way to do that? Would this send a shadow code, or should the light come on? The check engine light did not and is not on.
Old Aug 13, 2005 | 07:16 AM
99Automagic
About the drop resistor..
I haven't heard of anyone throwing a code when they do the mod. Activating the mod would be the same as a disconnected/malfunctioning resistor isn't it? So maybe a bad resistor wouldn't throw a code? Unless you've had experience with a bad resistor in the past and a code appeared.
Old Aug 13, 2005 | 10:21 AM
njmaxseltd's Avatar
If I remember correctly, the guys that run the mod that switches the drop resistor out do throw an error code.
It's easy to check it, just remove it from the circuit and measure it with an ohm meter. I think it's value is 12 ohms. Somebody please correct me if I'm wrong.
Old Aug 13, 2005 | 10:58 AM
mbandi's Avatar
I just went out and started the car and the cel stayed on. Checked the codes and I do have a 1205. Good call. I guess it's time to bust out the Fluke meter and follow the chart. I'll let you know. Any suggestions welcome. Thanks in advance for all your help.
Old Aug 13, 2005 | 01:35 PM
cds166's Avatar
Interesting my max does the same thing, but not all the time
Old Aug 15, 2005 | 06:26 AM
mbandi's Avatar
The Dropping resistor has Failed!!
That was the problem. I have another one coming from Nissan. Mine was a completely open circuit, no continuity at all. I must admit, I loved the 2-3 and the 3-4 shift, even the lock-up apply for the torque converter clutch was good, but the shift into second felt like the car was going to explode!! My question is, is there a way, besides the wide open throttle mod, to just give the dropping resistor a slight resistance adjustment in order to raise line pressure just a little more? Most automatic transmission shift kits, especially the ones made by Transgo have updates to increase line pressure from the factory spec because most of the newer cars are designed toward comfort rather than shift quality. I've rebuilt and installed shift kits in a lot of domestic transmissions but have little expierience with the one in my own car. I assume that a slight adjustment in the dropping resistor resistance could increase line pressure slightly enough to give you solid, fairly firm shifts for everyday driving. Any thoughts?
Old Aug 15, 2005 | 06:29 AM
99Automagic
HA!!
I finally got something right.
Old Aug 15, 2005 | 07:00 AM
Jime's Avatar
There are ways to raise the line pressure slightly my modifying the valve body . However I have tried every resistance combination possible using a variable resistor and have not found anything that will give an increase other than full. It seems that it acts just like a switch and by reducing or increasing the resistance it will work normally until a certain point and then bang its full line pressure.
Great idea but just doesn't seem to work.
PS I get a 0745 Pressure Solenoid code from the DR Mod. Not always but eventually after a few runs. Sometimes it happens first time I use it.
Old Aug 15, 2005 | 07:18 AM
mbandi's Avatar
Thanks Jime, I assumed someone had already tried it. Too bad. Have you used any specific shift kits for your Max with sucess?
Old Aug 15, 2005 | 11:25 AM
Jime's Avatar
I just use the DR Mod on a WOT switch. My only real reason for wanting a faster shift is for the track so I haven't really tried anything else. I really don't mind the stock shift speed for everyday driving.
Old Aug 17, 2005 | 01:18 PM
alpimax99's Avatar
anyone know what the real 0hms value of the drop resistor is i saw 12ohms but he wasn't sure?
Old Aug 17, 2005 | 04:39 PM
Jime's Avatar
Thats correct.
MaxStock
Dec 5, 2016 05:19 PM
ef9
Oct 4, 2015 08:43 AM
Andy29
Sep 29, 2015 05:32 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
