Transmission Question
Old Aug 16, 2005 | 08:10 AM
enjetek's Avatar
hey guys/girls,
i was wondering if anyone could help me out with this problem. i actually brought in my car to a nissan dealership because I was too lazy to do my oil and had my timing belts replaced. Anyways i didnt really notice this problem until after i got it done (which was in 8/13/05). Anyways, the problem is as follows:
sometimes the car makes a lurching sound whenever i shift into reverse or drive after releasing the brake pedal. it does not always happen but it does make a weird sound. after i give the car some gas it does go away. it also appears to only happen when i have let the car sit without warming it up. the shifting is smooth but the lurching is evident only after i release my brake pedal. i put in some extra transmission fluid just to be safe and i have an auto. thanks for any help.
-myke
Old Aug 16, 2005 | 08:24 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
your doesnt have timing belts. it has a timing chain designed to last the life of the engine. if your repair order says timing belts changed. go back and get your money back. lurching sound or lurching movement(hesisation) could be bad coil packs.
Old Aug 16, 2005 | 08:26 AM
enjetek's Avatar
hmm they mentioned something about the serpentine belts? i forgot the name of it but it did have cracks in it. how much would it be to fix the coil packs?
Old Aug 16, 2005 | 08:50 AM
MDeezy's Avatar
drive belts run about $20 each belt (there are 2) a coil pack runs abour $70 each.
Old Aug 16, 2005 | 09:02 AM
enjetek's Avatar
sweet. should i attempt to do the coil packs myself? the drive belts are complete but if a larger consensus believes it to be the coil packs then i will get it fixed. how many will i need to buy and how difficult is it to do?
-myke
Old Aug 16, 2005 | 09:20 AM
MDeezy's Avatar
coil pakcs are as easy as pluggin in a toaster, no exaggeration. You should get a cel is a coil pack is failing, that cell would tell you which cylinder it belongs to.
Old Aug 16, 2005 | 10:16 AM
Dan's Avatar
Dan
No Longer Owns a Maxima
Try disconnecting each coil pack one at a time. If you notice a change in engine idle sound before/after, then it's a good coil. If there is no change, probably a bad coil.
Old Aug 31, 2005 | 01:55 PM
trademark's Avatar
if ur coils are no good ur engine light should come on
Old Aug 31, 2005 | 03:09 PM
MaxLine702's Avatar
I have a question also....I'm looking forward to swapping my 95 auto for a 5 speed and i've been looking around for a tranny. I need to know if it really makes a difference of either getting the locking or non-locking differential? Also about that production date stuff...is it critical i have the correct one?
O yeah does anyone have a 5 speed tranny they are selling? I'm in desperate need of one, looking around $600-$800 for one. (Sorrry i would've posted this in the classifieds but the forums won't let me post new threads!)
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
The Wizard
24
Oct 1, 2015 08:47 PM
I<3 A32's
Sep 10, 2015 11:07 AM
videomano
Sep 8, 2015 03:28 PM
