K&N Drop in
K&N Drop in
What kind of K&N filter do I need that would fix the Maxima? Do they come in different sizes?
It should just drop in right? Then I could take off either the top or bottom piece from the airbox to increase air flow and sound?
Would it still sound as good as a pop-charger?
Originally Posted by Bobo
You shouldn't be taking off the top or bottom piece of the airbox. You could try the hacked airbox mod with the K&N panel filter, but who needs the racket?
Just buy the K&N filter, drop it in, and call it a day.
You just specify the year of Maxima you have. The drop-in air filter is the exact same size as the Nissan OEM or any other after-market paper air filter. This isn't rocket science.
It breathes better than a paper air filter and there is a bit of a growl from it at WOT, particularly when combined with an after-market y-pipe, such as Budget which is what I have.
.... open tabs holding down airbox closed... remove old filter.. put in new filter.. and if you want to do the flipped airbox thing... loosen the clamp(hose tightening thing wiht screw) right after the box where the filter is.. rotate up... and tighten back.. and use a zip tie or two to hold donw the airbox.. its sounds wicked loud.. and annoyed the hell outa me afer... 1 min...
I posted this in another is thread asking weather or not the K&N was worth it.
Originally Posted by Maxima lover
I decided to go get some proof on weather or not the K&N actually improved acceleration over a generic paper filter. I mounted my radar gun to the dash and grabbed a stopwatch. I went to an industrial road with no traffic that was straight as well as flat. Since I have a 5 speed I didn?t want the results to be affected by my launch, so I got it going in first gear and let it off the gas and let roll on its own at 4 MPH. Then I punched it and started the stopwatch. I stopped it as soon as the radar gun read 60.
I did 3 runs with the K&N that has about 6k on it, then I did 3 runs with the Fram that has about 3K on it, then 2 more with the K&N, and then 2 more with the Fram.
K&N
8.18
8.14
8.10
8.16
8.23
Fram
8.46
8.43
8.40
8.37
8.50
K&N average- 8.16
Fram average- 8.43
I have nothing performance wise done to my car yet. The only thing different from stock about my intake is 1 3" hole in the air box. I tried as hard as I could to make the results as accurate as possible.
K&N
8.18
8.14
8.10
8.16
8.23
Fram
8.46
8.43
8.40
8.37
8.50
K&N average- 8.16
Fram average- 8.43
Mar 12, 2020 12:06 AM
Turbonut
46
Oct 21, 2015 08:28 PM
maxima-junky
Oct 7, 2015 06:13 PM
