Toe is 0.65...rear alignment problem
Old Aug 27, 2005 | 02:09 PM
Albert's Avatar
After going for a wheel alignment, it was discovered that
my rear driver side wheel has toe = 0.65 degree. This has been
causing my car to pull to one side hard. For a 4th gen, I
believe that the rear is non-adjustable.
How can I fix this?
Old Aug 27, 2005 | 02:33 PM
nick's Avatar
replace rear axle/beam - or have auto body shop bend it back to specs
reolacing it might cost you less if you do all the work yourself and locate cheap used beam.
thats what i had to do with mine. The bottom moutning brackets for rear shock got bent out of shape during my spin out on the freeway( damn RSB and Sprint springs) and resulted in alignment beeing out of specs.
Nick.
Old Aug 27, 2005 | 06:10 PM
vsamoylov
its bent. you must have hit something with the rear of your max.
Old Aug 27, 2005 | 08:14 PM
JSMax's Avatar
Sold
an alignement guy told me that I could have the rear of mine shimmed to bring it back into spec. My car is just on the edge of spec and I figured that it wasn't worth it. Maybe ask the alignment shop if this is an option for you.
good luck.
matts95max
Apr 23, 2025 10:44 AM
NewMax03
Oct 7, 2015 08:27 AM
06maxima55
Sep 28, 2015 04:29 PM
ivorton23
Sep 26, 2015 09:47 AM
