Code 0503...Ignition coils?
Old Aug 30, 2005 | 10:02 AM
Justaguy's Avatar
I keep getting this 0503 code (problem with front Oxygen right side...) The OS was replaced, wires were checked and I still get this code.
The car does seem to mis-fire, and I feel the loss of power when driving (I guess cylinder 1-3-5 is misfiring)?
The spark plugs were also replaced with the recommend NGK.
Fuel Filter was not changed
Injectors was not cleaned
Cleaned Throttle body
Changed Air Filter
Changed Knock Sensor
Replaced PCV Valve
Is my next option replacing 1, 3 or 5 ignition coil??
1997 maxima, 90,000 miles
Old Aug 30, 2005 | 10:11 AM
Justaguy's Avatar
..I also noticed this little strange, maybe hidden feature..
When I reset the ECU, I turned the screw to quicky twice, and the ECU was not properly reset. I started the car and drove off..I notice that the "Check engine light" was blinking..hummm..if I let go the gas, it stopped, when I added gas it blinked faster, and at about 40mph, it just stayed on (did not blink)...when I slowed down it would blink at various speeds until it would stop blinking when fully stopped...I wonder if this is some kind of "debug" mode for the 0503 code to pinpoint which cylinder is misfiring
just a thought..
Old Aug 30, 2005 | 10:25 AM
njmodi's Avatar
Do I get a tax break?
Which O2 sensor did you replace? i.e which one do you think is the front-ride side?
(I just want to make sure you replaced the right sensor).
A flashing CEL indicates a severe misfire... not good.
Old Aug 30, 2005 | 10:39 AM
Loe max's Avatar
You didn't reset the ECU, you placed the ECU into a 'real' time diagnosis mode.
Old Aug 30, 2005 | 10:49 AM
Justaguy's Avatar
It was the very first one...the 1st pipe going down to the motor.
Old Aug 30, 2005 | 10:51 AM
njmodi's Avatar
Don't know what you mean by first pipe, there are ar 2 in there - here is a pic:
http://www.courtesyparts.com/A32_O2-sensors.html
You should have replaced the one marked Front Passenger Side (RH) - in the y-pipe, closest to the firewall.
Old Aug 30, 2005 | 05:42 PM
Justaguy's Avatar
dam. I replaced the wrong one then. When you open the hood and look down, that is the OS I replaced (near the fan) and not the one near the firewall...crap I even thru it out too.
Thanks for the reply and pointing me in the right direction.
Old Aug 31, 2005 | 06:09 AM
njmodi's Avatar
Oops! well - live and learn - go buy another one and swap out the correct on this time.
Old Aug 31, 2005 | 08:09 AM
Justaguy's Avatar
..but would this be the cause of my problem?
I hope I don't have multiple problems happening here....reading all these ignition coil problems is getting me all nervous.
If I can ask one more question...has anyone changed the back ignition switch?
thanks
Old Aug 31, 2005 | 08:39 AM
mendon99's Avatar
tastey wheat
if you have an autozone in your area, they can check ignition coils in our cars to see if they're bad. i wish i had known this before i did a bunch of other crap, i had cylinder 2 misfire.. turned out to be the ignition coil.
Old Aug 31, 2005 | 09:00 AM
njmodi's Avatar
0503 has nothing to do with ignition coils. Replace the O2 sensor.
Old Sep 2, 2005 | 07:48 AM
kelster23's Avatar
When you replace a bad part do you need to reset the ECU? I've swapped out my O2 sensors and the check engine light has gone off on itself.
Old Sep 2, 2005 | 07:50 AM
njmodi's Avatar
Yes, you should reset the ECU. However, the light will go off by itself (eventually) once the parts have been replaced, because the ECU will detect that the part is now working properly, and after a preset number of cycles, it will clear the error code.
Old Sep 29, 2005 | 12:29 AM
sflover0099's Avatar
I just change my Front Right O2 today and I haven't reset the ECU. How long the light will go off by itself? So far, I drove around a bit and the light still on. How to reset the ECU?
My car is 1996 GXE
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
