Can UDP and sound system work together?
Old Sep 3, 2005 | 01:25 PM
blueice's Avatar
First of all, how much power if any can you notice in seat of the pants with underdrive pulleys? Is it really worth it or is there a risk of ruining the harmonic balancing of the crankshaft and messing up the engine? (I know that was the case on an E36 BMW)
Secondly, if I would notice better acceleration, is it ok to run the pulley with a powerful sound system? Would I strain the alternator? I do have a power capacitor and an Optima Yellow Top battery.
Old Sep 3, 2005 | 01:34 PM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
I read somewhere that an UDP isn't recommended in conjunction w/ a powerful stereo
Old Sep 3, 2005 | 02:07 PM
Stuntin' 101's Avatar
the under drive pulley slows down the spining of your accessories. (alternator). im sure you could still run a system though.. just how big are we talking about? and yes getting a cap would be a VERY good idea.. along with a good battery of course
Old Sep 3, 2005 | 02:26 PM
zander's Avatar
If you have, or are planning to get, a huge stereo set up dont get the UDP. The gain will be small and useless if you are hauling around a heavy system. IMO a UDP is for someone trying to get every last bit of hp out of their car, to make it as fast as possible. Its the very last mod you should do... In my other car the power steering pump went bad so I removed it, eliminating the pully, and noticed no real gain in acceleration, the car felt sportier though.... And that was essentially "underdriving", but a full 100%, weight and rotation
Old Sep 3, 2005 | 02:39 PM
blueice's Avatar
ok, so a pulley isnt wise for me to get.
It does sound contradictory to have a system and want more speed, but there is a balance in the middle for me. I want it to feel fast and also bump hard.
I have two 12" hollywood sound subwoofers in their own ported boxes and a JBL1200.1 amp. Even with the capacitior my lights dim with the hitting of the bass. I havent noticed as much dimming since getting the yellow top battery... in my E36 the engine idle speed would drop 200 rpm when the bass hit!
Old Sep 3, 2005 | 06:29 PM
sunten1
Ok a few more questions...I take it your running your system at 1200 watts?
If so I don't think its a good idea to get the pully. Because of the fact that your just running to many watts and your going to be putting ALOT of stress on your alternator. What I would suggest is doing the "BIG 3" also known as grounding the battery to the chassis, alternator to postive battery, and last battery negative to engine block. You really don't need a cap. Its more like a bandade your just hiding the real problem. If you want more information on this, in more detail, I would head into the Audio/Video Forums on this board and ask them. I am almost sure theyll will tell you the same.
Old Sep 3, 2005 | 07:00 PM
PAREDLINE's Avatar
Use 2 or 3 big capacitors in your wiring and you should be ok. does anyone know the voltage produced after using the underdrive pulleys? It has to be over 12 (to charge the battery) but will be under 14.4 (stock pulley).
Old Sep 3, 2005 | 07:05 PM
Matt93SE's Avatar
STFU n00b!
I've had a 2500W RMS system in my 3rd gen for three years and still the factory original alternator at 225,000 miles.
even with the underdrive pulley on my car, my alternator was still putting out 75A @ 13.4V at IDLE.
rev it up to 2-3000rpm and the thing was dumping out 100+amps at 13.8V.
Do the big 3 on wiring, then stick a 1 or 2 farad cap back there with the amps. no problems with dimming here, even when I'm rattling the sunroof out of my car.
stay away from those 40F "BatCaps" and crap like that.. the ESR is so high on them that they're nothing but small batteries. stay with a good quality, low ESR, electrolytic cap- which typically you never see higher than 2F.
Old Sep 3, 2005 | 08:26 PM
maxgtr2000's Avatar
KH3 by popular demand
If you don't have a y pipe yet I would get that instead of the pulley, that should give you more performance than the pulley and do the big 3 upgrade like sunten1 said that will even help your present voltage issue. If you do decide to go with the pulley you can get your alternator rebuilt to bump up the voltage for about $50. I think with the pulley you lose like around 25 amps but that is only at high rpm, it depends on the stereo amperage needs. Some people said they didn't notice a difference in their stereo.
Old Sep 4, 2005 | 09:03 AM
gtr_rider's Avatar
192.168.1.1
UDP does actually carry a Supercharger pulley which is light weight, but is sized like a normal OEM pulley.
JRod28
Dec 29, 2023 09:56 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Abdelrhman
Aug 17, 2015 12:16 PM
kenc15
Aug 5, 2015 08:29 AM
