flex section broken
Old Sep 9, 2005 | 05:29 PM
dayglo's Avatar
flex section broken
i think that its part of the y-pipe... its the flexible joint right at the front where it goes up
is that my y-pipe?? i cant see much of theshape when i lookunder the car , or else i could do the math..
well,its broken and my exhaust is loud an i need to fix it
any suggestions anyone? thanks
Old Sep 9, 2005 | 05:49 PM
njmodi's Avatar
Do I get a tax break?
Yes it's part of the y-pipe.
Options:
1. Have an exhaust shop weld a new flex section onto the existing y-pipe
2. Find a used y-pipe in the classifieds forum and swap it out
3. Nows the time to get an aftermarket y-pipe (new or from the classifieds) and swap yours out.
I would recommend option 2 or 3.
Old Sep 9, 2005 | 09:53 PM
BlueC's Avatar
wat
You can find flex sections on ebay. Usually around $25-30 shipped. Shop would probably charge another $20-50 to weld it in.
Old Sep 10, 2005 | 01:01 AM
dayglo's Avatar
cool thanks for the replies, i was just trying to make sure it was the y-pipe i need to buy. i need an aftermarket one anyways,
which one is the best y-pipe?
Old Sep 10, 2005 | 05:39 AM
Bonka's Avatar
Schnell kaputt
Either buy a used one in the Classifieds here of get a Warpspeed SS. I'm leary about recommending the Budget (I have one) ever since they branched out to LSS they've been having quality control issues on some pipes. The old pipes when LSS was Budget were fine.
Is the noise really loud? My stock flex when I took it out was slightly damaged but didn't cause an increase in noise..
Old Sep 10, 2005 | 05:54 AM
crsdsabers's Avatar
One of the "pointers" on WSP's installation guide is to ensure that you use a hanger to the rear of the flex section. They say that lots of folks don't and the Flex section isn't designed to bear weight, thus the failure of flex section.
Old Sep 10, 2005 | 08:33 AM
dayglo's Avatar
yeah im pretty sure youre right, some hose clamps used as brackets were holding up some of the b-pipe but rusted and fell off. i didnt replace them and im thinking that it lelt everything shift and sag, and move around. makes tons of sense now, it probably would have lasted longer without the load on it...oh well iv wanted that 10hp for so long now
its not so loud, but alot more loud than what it was before. i noticed the exhaust get more loud as it broke but didnt realize what was happening. i thought that the new muffler i got from blackcat was coming a bit loose. oh well no big deal
mmm new y-pipe
thnks all and make sure your exhaust isnt raattling around
Old Sep 10, 2005 | 12:19 PM
cefiro8701's Avatar
sorry to jack the thread BUT...
flex pipe leaks can be solved by exhaust wraps right?
Old Sep 10, 2005 | 02:03 PM
wetzelman1's Avatar
This thread popped up just as my own flex section just got a tear in it. Is this a repairable issue, or does it require an entire replacement?
Old Sep 10, 2005 | 02:24 PM
1FSTMAX's Avatar
no!.........
Old Sep 10, 2005 | 02:28 PM
2 Da Max's Avatar
no sorry to jack your thread, but 1fstmax, what rims are those!! that shiet is hot, anymore pix?
Old Sep 10, 2005 | 03:00 PM
cefiro8701's Avatar
Originally Posted by 1FSTMAX
no!.........
but bees-in-a-can can be solved by wrapping right?
Old Sep 10, 2005 | 03:55 PM
1FSTMAX's Avatar
you're only masking the problem..
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
