KS changed in record time
Old Sep 11, 2005 | 01:46 AM
killerVQ30DE's Avatar
I had put off installing the knock sensor because I had heard it was a real mission.. well with the below its really quite simple and pain free
My knocksensor had a big crack in it, but it still registered the 560ohms when testing.. so testing won't always show if its dead or not .. just check the codes or pull it to see
I used the method in the 4th Gen FAQ.. had the knock sensor out in about 20mins and not a single cut
I used this setup of extensions:
1/2 socketdrive + 1/2to3/8 + 10"3/8 extension + 3/8to1/4 + 1/4 swivel + 1/4 12mm
I found the grabber tool the easier way to position the bolt and knocksensor apon replacement. You will still need a magent pickup tool incase you drop th e bolt in an awkward spot like I did in a bit of a valley.
Old Sep 11, 2005 | 02:55 AM
Nismo's Avatar
Thank you for the pix of your tools. I gotta change mine soon and still need a set of 1/4 sockets & extension.
Old Sep 11, 2005 | 05:11 AM
4x4Max's Avatar
Thats pretty quick, but definatly not record time. Rome changed mine in like 10 minutes. Do you feel an instant increase in power or not? People say it takes time, but i felt it on my first drive about 10 min after putting the new sensor in. The car pulled harder with 3 people in it than it did when it was only me with a broken KS. Amazing results, but my KS goes retarded sometimes and loses all power again, and then comes back.
Old Sep 11, 2005 | 07:42 AM
MDeezy's Avatar
I changed it on my brothers in 6 mintues
Old Sep 11, 2005 | 08:02 AM
Maxima99SE's Avatar
will fly for food
wanna try mine?
Old Sep 11, 2005 | 08:18 AM
MDeezy's Avatar
Originally Posted by Maxima99SE
wanna try mine?
Bring it on. . .
Old Sep 11, 2005 | 08:20 AM
sonicrunch's Avatar
Yep, that grabber tool and magnetic pickup is the way to go. I didn't have to reach into the valley of death at all.
Old Sep 11, 2005 | 08:29 AM
MDeezy's Avatar
I had used no grabber tool. Just a 1' extention and universal joint. I was suprised how fast and easy it was, my brother reached in one time, came back with a bloody hand.
Magnetic tool would help with that big botl
Old Sep 11, 2005 | 08:58 AM
MaxGordon7's Avatar
my sisters small hands fit real nice inside of there, other wise i would still be working on that KS.
Old Sep 11, 2005 | 09:47 AM
MaximaSpd85's Avatar
we used some electrical tape on mine, stuck it inside the socket
Old Sep 11, 2005 | 12:40 PM
Is that sarcasm Thought I'd put pic of tools as none of the other instructions do and it helps you to visualise the process more. I used 3/8 extensions as I had them and they are more handy to have if you need to buy extensions
Bit getto though, the tape might stop the KS being earth properly or the tape could melt making a bad ground
But how long did it take to change yours the first time
My record time, was ahh a personal one, it wasn't such the PITA people say.
Results, Felt the power return straight away, and did NOT need to reset
the ECU, scanned the codes with consult and got the 55(no errors) straight away... Nailed it hard round the block and up some hills, rescanned, an NO CODES .. wheels break loose easy.. and I'm Auto
Old Sep 11, 2005 | 02:28 PM
Maxima99SE's Avatar
will fly for food
Bring it on. . .
coming to nopi?
:cough redsectionA cough:
Old Sep 11, 2005 | 02:30 PM
JClaw's Avatar
It's so easy on the 3.5. 2 minutes.
Old Sep 11, 2005 | 04:14 PM
MDeezy's Avatar
coming to nopi?
I wish, gotta spend what money will get on changing my axle out and putting a new control arm on.
Sure rub in the fact you have the 3.5 under your hood
Old Sep 11, 2005 | 06:19 PM
vortechpower's Avatar
I thought the knock sensor didn't throw codes? Would a bad knock sensor cause any hesitation?
Old Sep 11, 2005 | 06:22 PM
MDeezy's Avatar
lt didnt but its stored in the ecu so you could scan for codes and pull a 0304.
Old Sep 11, 2005 | 06:35 PM
90stanza's Avatar
it doesnt show unless you check for codes, if it's bad it wont turn the check engine light on.
Old Sep 12, 2005 | 01:38 AM
Nismo's Avatar
No sarcasm at all. I was testing some of my tools earlier and thats when I found out that none of my 3/8" univeral joints would work in there so I need those 1/4 joints
Old Sep 12, 2005 | 06:48 AM
diy_dreamer's Avatar
it doesn't throw the CEL, but it does throw a code.
Old Sep 12, 2005 | 03:15 PM
95MaxTampa's Avatar
What exactly are the symptons of a bad knock sensor? Would a faulty k.s. cause a car to pulsate (looses and quickly regain power) at a steady speed of 60 MPH? This is the problem that I'm currently having. It also stalls (randomly) at stops.
Old Sep 12, 2005 | 03:38 PM
My standard answer for this is the ECTS (Engine Coolant temp sensor).. check the stickies
Old Sep 12, 2005 | 03:53 PM
MDeezy's Avatar
A loss in power, acceleration takes longer, but maybe more noticable gas economy dropping signifigantly.
Old Sep 12, 2005 | 04:21 PM
Maxima99SE's Avatar
will fly for food
230 to a tank, mine is dead.
Old Sep 12, 2005 | 04:38 PM
MDeezy's Avatar
Damn! I'd say its dead alright. Sure an o2 sensor isnt out also? Luckiy gas prices are dropping around here.
You have the new KS already?
Old Sep 12, 2005 | 04:56 PM
deezo's Avatar
I think Joe does them in 8 minutes. I can't even get my hands in that area so I had to call him to do it on mine.
Old Sep 12, 2005 | 05:00 PM
MDeezy's Avatar
I surprisingly got my big assss hands in there, wasnt easy. Mainly I had a light shines in the KS area and dangled my universal joint off my 1' extension and seated it on the ks. I'm still shocked I did it so quick.
Old Sep 12, 2005 | 05:02 PM
CalsonicSE's Avatar
I swear Turbo95Max changed mine in less than 5 min.
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Team STILLEN
Aug 10, 2015 04:29 PM
RealityCheck
Aug 5, 2015 06:18 AM
