if replacing auto shift knob with aftermarket one . ..
Old Sep 12, 2005 | 03:26 AM
Maxride99's Avatar
if replacing auto shift **** with aftermarket one . ..
If I buy an aftermarket shift **** for my automatic how would I incorporate the OD button? any ideas?
Old Sep 12, 2005 | 03:53 AM
elambert24's Avatar
Generally you will be able to buy a **** with or without an OD button. So buy one with OD, disconnect the OD wires from your stock ****, attach them to the wires from the aftermarket one and your golden.
Old Sep 12, 2005 | 04:23 AM
maxZ93's Avatar
switches
when i had my 3rd gen, i encorporporated a 12v switch somewhere on the cemter console. I f i were you, put it somewhere near where the heated seat switched normally go on the center console.
Old Sep 12, 2005 | 04:34 AM
Nismo's Avatar
Any on/off switch will work
Old Sep 12, 2005 | 04:39 AM
98maximaSS's Avatar
you need to get a momentary switch not just any flip switch you can get one from any radio shack or electronics store.
Old Sep 12, 2005 | 04:53 AM
Nismo's Avatar
actually any flip switch (on/off) works. Momentary will only activate when you push it down so that means once you let your finger off of the button, the od will turn back on.
Old Sep 12, 2005 | 08:49 AM
cefiro8701's Avatar
aka "poor man's nitrous"
sorry...but stick with the flip switches...i like the way it looks.
Old Sep 12, 2005 | 10:34 AM
chenzarino's Avatar
get a Levoc ****, has the od button and is very nice looking to boot
Old Sep 12, 2005 | 11:44 AM
98maximaSS's Avatar
i had a on/off switch and to turn o/d off you had to turn it on and then off to get the O/d to turn on or off i drive a 98 maxima and mabye the wiring was diff. but i dont think so i went and picked up a momentary switch and now when you u hit the button it turns it on because the switch must be activated and deactivated for the computer to turn it off check your regular handle watch the switch when you press it it goes in and comes out to the same length it doesnt catch and stay depressed leaving it connected take the bare wires for the o/d switch touch them together and take them apart it will turn it off do it again and it will turn it on
Old Sep 13, 2005 | 01:57 AM
Nismo's Avatar
Yea I think your 98 was different because before I converted to 5speed, I had an aftermarket auto **** with no od button and a simple on/off toggle switch worked for me. Also If I remember, the 97 od button was the opposite than yours since it stays in when you push it and comes out when you push it again.
Old Sep 13, 2005 | 04:10 AM
robsst's Avatar
FYI: I think the early 4th gens are different from the later 4th gens.
In my 95 & 96 Max, it feels like a regular switch. My 99 I30, the switch feels like a momentary switch. This may be the cause of the confusion about the switch type in this thread.
Old Sep 13, 2005 | 05:16 AM
98maximaSS's Avatar
yea probly but its all good i just wanted to make sure we wernt giving him false advice sorry for the confusion
CorollaULEV
30
Aug 9, 2021 08:11 PM
mpbclutch33
Aug 25, 2015 06:23 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
PhalC1
Aug 5, 2015 02:36 PM
