Automatics with over 100K..step in
Old Sep 15, 2005 | 07:03 PM
  #41
MaxGordon7's Avatar
lost mine at 86k, make sure your fuild is full before you drive it 2 quarts low I drive hard and it shifted smooth, ive been looking at VB MOD.
Old Sep 15, 2005 | 10:00 PM
  #42
aminus21's Avatar
Anyone ever try Lucas transmission additive??? It supposedly helps slipping, and can be used as preventive maintenance.. Not recommending it, just seeing if anyone has any experience with it..
Old Sep 15, 2005 | 10:06 PM
  #43
kobalt's Avatar
Not a 4th gen but for what its worth just turned over 138k with no problems whatsoever
Old Sep 15, 2005 | 10:42 PM
  #44
Garrick's Avatar
133,119 and still owning the streets.
Old Sep 15, 2005 | 10:43 PM
  #45
serenity97's Avatar
automatic trans
I have 266,000 miles on my 97se. The original automatic trans and engine are still holding on. The trans slips a little bit but is still ticking. I have to admit though, I didn't regularly change the trans fluid like I did the oil. Since I had the car (bought it used with 46k miles in Sept 99) I have only changed the trans fluid twice............ Who knows, but I am not complaining. I have definitely gotten my money's worth!
Old Sep 16, 2005 | 01:14 AM
  #46
Juice_818's Avatar
98'850 here and running great....i been vey satisfied with my max still runs as good as when i first got it with 24k
Old Sep 16, 2005 | 02:14 AM
  #47
L.I. I30t's Avatar
i have 127,000 and drive my car almost 500 miles a week. I flush my tranny with nissan matic d tranny fluid every 30,000-40,000 miles. You can always tell when it is time to change you fluid by checking the dip stick. Take a napkin and drop a liitle tranny fluid on it and see if it doesn't spread or looks dark in color.
Old Sep 16, 2005 | 03:07 AM
  #48
DpG $h0rTeE's Avatar
Just past the 100k mark about a week ago and tranny seems fine. Still able to chirp into 2nd due to DR Mod.
P.S. Get yourself an auxillary tranny oil cooler and your tranny will love you for it.
Old Sep 16, 2005 | 04:21 AM
  #49
komodo693's Avatar
218k and running strong - have only changed the fluid 3x (every 60 even if its clean) other than that nothing
Old Sep 16, 2005 | 04:55 AM
  #50
robsst's Avatar
I have a 95 Max with 160k and a 96 Max with 130k and so far, no problems with the tranny at all, knock wood. Never changed the fluid on either. My wife was driving the 96 up until recently, so it has had it easy. I drive the 95 pretty hard.
Old Sep 16, 2005 | 05:02 AM
  #51
kbmaxima's Avatar
100.5k and still going. 1-2 and 2-3 shifts are getting harsher and harsher and bucks the entire car, but no slipping. No CEL or tranny code with the o/d light. shift solenoid or resistor maybe? but yea, still going. i'm riding her til 200k before i think of getting a new car.
Old Sep 16, 2005 | 06:07 AM
  #52
Xmax's Avatar
Originally Posted by MaximaSpd85
hey xmax, wut r ur mods? ur cardomain says u only have an intake of some sort, and ran a 14.8 in an auto...sounds good
ypipe, udp, and fart can muffler
Old Sep 16, 2005 | 07:35 AM
  #53
Scott LaRock's Avatar
95 max with 127k on it, never checked the trans fliud, where's it at in the car?
Old Sep 16, 2005 | 07:56 AM
  #54
Dubbya's Avatar
VK56 Inside
I used it and it did nothing. Mine may have been so far gone that it wouldnt matter either way though.
Old Sep 16, 2005 | 08:05 AM
  #55
ArcticW's Avatar
perfect, 123K, it was a hand me down from my dad, he drove it like a grandma...ive had it since 90K and i have only just begun to mod, so only time will tell
Still shifts like a charm, again, hand me down from pops , could use a change in fluid though .....
168,887 and counting......
Old Sep 16, 2005 | 09:03 AM
  #56
sonicrunch's Avatar
I wish my shifts would get harder.
Old Sep 16, 2005 | 09:55 AM
  #57
tucker's Avatar
Gents,
Can't believe knowone mentioned using a tranny oil cooler. I got 3-max's, 2-3rd gen and a 4th gen. After replacing a trans in a 3rd gen I got a real education on transmissions especially front wheel drives. The fluid gets hotter than motor oil. Everybody do yourself a favor and add an oil cooler. They're about $35 and will save you big money. Run Amsoil or Redline ATF and you should be good for another 200K The trans shop that rebuilt my trans says any front wheel drive, especially mini-vans, is on borrowed time after about 110K. Looking around his lot at the vintage of cars that needed rebuilds made me a believer. Just about everyone on the 3rd gen forum with an auto is running a trans cooler.
Old Sep 16, 2005 | 10:43 AM
  #58
Dubbya's Avatar
VK56 Inside
I have an oil cooler. I forgot about it.
Old Sep 16, 2005 | 12:32 PM
  #59
AGRECORDS
i just got a new/used one today to replace my tranny at 140k.. it still run good but all the clutches slipped so my new/used one is going to be good.(330) bucks at 81,000 good condition.you cant beat that!
Old Sep 16, 2005 | 12:34 PM
  #60
AGRECORDS
hey where can i get a oil cooler for my 96 maxima? easy to install?
Old Sep 16, 2005 | 01:06 PM
  #61
maxultra's Avatar
I bought mine used about 2 months ago with 220k. I thought the tranny was dead because of the bucking. I found out it was a bad coil and now that the problem is fixed the car runs amazingly smooth(Finger crossed).
WES
Old Sep 16, 2005 | 01:22 PM
  #62
Dubbya's Avatar
VK56 Inside
Google is your friend. I have the Hayden Model 405. Took about an hour to install. There is a write up in the stickies.
  #63
Bonka's Avatar
Schnell kaputt
I've got under 54,000 miles on mine it shifts fine but a couple of times this week I gun it and I get a slight hesitation; I think it's the gas though.
About the transmission cooler, it's worth the money. I bought the biggest one Jegs sold still waiting to install it. I think deezo also has a huge one installed he probably has a better idea of if too big would be a problem. I wouldn't think so.
Old Sep 16, 2005 | 01:37 PM
  #64
RockfordMax's Avatar
Back from the dead
its glorious. original tranny, 122k. honestly tho im treating it like **** trying to justify a 5 speed swap lol.
Old Sep 16, 2005 | 01:40 PM
  #65
tucker's Avatar
Auto Zone, Pep Boy's etc. You don't need a bil one. It's plumbed in series with the cooler built into the radiator. Be sure you get an extra length of line. There's a how-to on the 3rd gen forum that explains the installation process. Expect to pay about $35.
Old Sep 16, 2005 | 02:10 PM
  #66
Aidan2474's Avatar
145K, I just noticed when I am riding along at about 40mph it wants to drop into 4th gear and there is some slippage/bucking/thumping noise. So what I do is keep the overdrive off until I hit about 55-60mph and all is well. Other than thateverything is fine.
Anyone else have this problem?
Old Sep 16, 2005 | 07:48 PM
  #67
Rbhays's Avatar
Originally Posted by xxsptcuztomsxx
all u maxima guys do urself a favor and upgrade the tranny with stronger parts before racing them...lol....they werent built for it....the were built for smooth comfortable cruising....
How many people do you think race maximas? Not that many last time i checked.
Old Sep 16, 2005 | 08:04 PM
  #68
abci30's Avatar
oh noes!!!!1111
115k and it slips sometimes thats why its being ripped out.
Old Sep 16, 2005 | 09:05 PM
  #69
maxS
95,000 runs like it should. One complain only: 4th gen TCM shift logic is not as good as the one on 2002 maximas.
Old Sep 16, 2005 | 10:41 PM
  #70
xCarreraGTx's Avatar
around 129K and here is what I found out today on the tranny. First, service engine soon light came up when I started the engine. I think it's stuck at 2nd gear or something cuz it barely hit 70 today when I was coming home from work and when I let off gas, the rpm just drops all the way down and rpm only goes up to 4 from what I remember. My car starts really slow from the stop like it has no power. I dunno if I should take it to the tranny shop tomorrow or pull out the codes before the shop. Can someone tell me if it's time for the new tranny or not?
Old Sep 17, 2005 | 12:52 AM
  #71
95jr6708's Avatar
Phenomenal transmission
mine is at 134 500 no problems with transmission at all. everthing works properly and smoothly. I have it flushed once a year as well.
Old Sep 17, 2005 | 03:19 AM
  #72
athlon omega's Avatar
I have a Hayden tranny cooler, and it's been working fine. However, since my car had been sitting in a body shop for 7 weeks this past summer, I noticed it shifts hard between 1st and 2nd. Should I change the transmission kit or get a flush? I currently have 153k on the max. I'm not the original owner of the car, but last time I did a flush was around 120k and tranny fluid was drained and refilled when the tranny cooler was installed. The fluid is still pink.
Old Sep 17, 2005 | 04:06 AM
  #73
maxspeed96's Avatar
180K and still good to go. Only changed the fluid once, but cant remember when.
Old Sep 17, 2005 | 07:42 AM
  #74
jazzbone's Avatar
I just bought my neighbor's 1996 with 178,000 miles. All original except for one caliper has been replaced. It runs great so far. My biggest fear is the tranny. Thanks for the advice on the cooler!
Old Sep 17, 2005 | 03:02 PM
  #75
SEinNE's Avatar
123 k. I'm middle of the road (for trans flush). Once a year is too often and a waste of $. Never isn't often enough. I do it every couple of years.
Old Sep 18, 2005 | 07:54 AM
  #76
scrhale's Avatar
I have 112K and it shifts a little harsh sometimes out of 1st. I bought the car from a grandma at 90K. This transmission is going to last . I need to start driving it like I stole it because this tranny HAS to croak.
OH NO DAD!!! MY TRANS IS DEAD!!! I AM PRETTY SURE A 5SPD TRANS IS CHEAPER!!! YES I WILL PAY HALF!!!
Hehe
Old Sep 18, 2005 | 12:24 PM
  #77
straight six's Avatar
98 Max GXE ~188,000 miles. Drive it every day, never any trouble with the tranny. As a matter of fact, the ONLY repair i've ever done on this car is replace a faulty 02 sensor and routine maintenance..........
Old Sep 18, 2005 | 12:54 PM
  #78
Back from the dead
Hehe
More like OH NO (insert guardian here)!!! MY (insert any part you dont like) IS DEAD!!! I AM PRETTY SURE A (insert aftermarket part here) IS CHEAPER!!! YES I WILL PAY HALF!!!
Sad thing is, chances are that it IS cheaper than OEM
Old Sep 19, 2005 | 01:24 AM
  #79
95GoldSE's Avatar
good at 146k
Old Dec 27, 2005 | 02:00 PM
  #80
SupaMaxima's Avatar
I have 215,000 on my car with the original transmission. It was running great until I went too fast in 3rd gear. Has anyone here experienced this type of problem:
When the shifter is in 1, 2, or 3 (D with O/D off)
-Gasing the pedal the car drives fine and shifts fine
-Releasing the pedal, the rpm dips and there's a high speed clicking sound.
-Gasing it again the car drives and shifts fine and there's no jerking at all.
Basically, the problem comes when I let go of the gas. When I have the shifter on D(OD On) the car drives like there were no problems with it.
Thanks for any input.
