z32 maf on 96 maxima!!!!!!!!
Only the #2 would really apply.
The Z32 is NOT plug and play. Besides the connections the voltage curve is different and would throw off your ECU readings unless you had it tuned accordingly. JWT is the best way to do this. The Z32 MAF is the same size as the A32 and there is no reason to use it unless you are turbo/SC and maxing out the A32 MAF.
it will read less air thus the ecu would read less voltage. the ecu would send less fuel and you would run lean. lean equals heat, and kills power since timing is retarded. the ecu reads the O2 sensors at part throttle and warm idling only, so depending on the voltage difference of the maf the car may run, but on cold starts and WOT kiss you car good by. the fule maps are preset and fuel would be insefficient. an afc may work to fix the problem you just created, but its not going to make any more power than the a32 maf and an afc.
you could swap in larger injectors to off set the z32 maf, but it will still be a waste of money.
kjlouis
Nov 24, 2018 06:09 AM
