topspeed y pipe . ..
Old Sep 18, 2005 | 10:15 PM
Maxride99's Avatar
if I got a topspeed y pipe but the person selling it did not have the hardware to go with it (ie bolts and gaskets) should i still get it if its a good deal? or are these items going to be difficult to come by? Thanks
Old Sep 18, 2005 | 11:04 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
Gaskets will cost you about $20 at the dealer and you use the stock nuts.
Old Sep 19, 2005 | 06:16 AM
maxgtr2000's Avatar
KH3 by popular demand
You need 3 14mm nuts and bolts to connect the front piece to the rest of the y if it was shipped to you in 2 pieces. Mine had an extra o2 sensor hole in too (for a total of 3), you may need to plug that.
Old Sep 19, 2005 | 07:30 AM
cefiro8701's Avatar
yeah..thats about it...and a trip to the local muffler shop would work.
Old Sep 29, 2005 | 08:36 PM
nad819's Avatar
Unfortunately if your bolts are all rusted, you'll be going to the shop no matter what-- I've had to do that for my y pipe and test pipe = not fun nor always cheap
Old Sep 29, 2005 | 08:38 PM
2 Da Max's Avatar
well i took a compressor, and an air chissel and broke the nuts off the cat. i then took a tap and dye set and installed the newer threads
Old Sep 30, 2005 | 05:59 AM
cardana24's Avatar
Blown
if you cannot reuse your old bolts that you take out of the y-pipe what size do you need to get to replace them?
Old Sep 30, 2005 | 06:20 AM
tavarish's Avatar
fwd gone rwd cr00
i just broke the stud off, and drilled a hole and put in my own bolt, make it however big you want it to be.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Quickywd01
Sep 21, 2016 09:36 PM
