compression testing
Old Sep 24, 2005 | 10:25 AM
sky jumper
compression testing
was looking at the standard compression testers with the rubber extension hose and 14mm adapters - is this what we need for the Vq30? how do you tighten the end of the rubber extension hose way down in the bottom of the spark plug tube? do you just twist the hose by hand and hope that you get enough torque out of it to get an air tight seal?? just seems like the rubber would twist before it gets tight enough.
also - the FSM says to disconnect the fuel injector control connections before testing compression - is there one central connector or do you have to disconnect each one individually? the back 3 are hidden under the plenum, but the FSM says nothing about removing the plenum first.
thanks.
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
knight_yyz
Nov 1, 2015 01:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
