18x7.5 rims rubbing on 300zx calipers or no?
Old Oct 3, 2005 | 07:06 PM
MaxObesset's Avatar
im thinking of purchasin some 18x7.5 Racing Hart C5 from a fellow org member but want to know if they will fit 300zx calipers without rubbing
Old Oct 3, 2005 | 07:08 PM
A Flood99's Avatar
they might and they might now
KNOW THE OFFSET
Old Oct 3, 2005 | 07:30 PM
Nealoc187's Avatar
SLOW
The answer is:
D. Not enough information provided
Old Oct 3, 2005 | 07:32 PM
Nissan 6's Avatar
The answer is:
Old Oct 3, 2005 | 08:17 PM
A Flood99's Avatar
yea ******* rly
Old Oct 4, 2005 | 04:41 AM
MaximaSE96's Avatar
Maxima Owner
generally i would say yes.....but it does depened on the offset of the wheel...also will u be using 13 Cobra Rotors or Z rotors
Old Oct 4, 2005 | 05:00 AM
mad-max98's Avatar
what's the minimum offset you have to have ???
Old Oct 4, 2005 | 06:46 AM
Shadow's Avatar
If they're RH Evolutions, the one piece wheels, then no they will not fit without spacers. I'm pretty sure the Evolutions only come in a 42 offset. A long time ago, I almost bought those rims, but the offset wouldn't clear the brakes. But a 10mm spacer would solve that problem.
If they're real Racing Hart C5's, the 3 piece version, then it will depend on the offset. By the 7.5" width though, it sounds like the 1 piece wheels.
Old Oct 4, 2005 | 07:00 AM
Iron Scimitar's Avatar
Tha Snatcher
i'm contemplating doing the upgrade...is a 35 offset enough? Probably not i'm running 18x7.5s as well.
Old Oct 4, 2005 | 07:16 AM
Shadow's Avatar
35 offset should be enough actually, but it may depend on the spoke design. My old 17"s were a 35 offset, then I had 42 offset 19"s with a 1/4 spacer, so effective offset was 36 or so. My new wheels are a +30 offset, and there is plenty of clearance.
Old Oct 4, 2005 | 08:19 AM
Tha Snatcher
my spoke design is rather complex.
Old Oct 4, 2005 | 11:17 AM
Maximus_95's Avatar
17x7 Velox 42offset
It clears but to the bare minimum.
i can only fit a credit card in between the spoke and the calliper. if i put 2 cards together, it touches the calliper and spoke.
Old Oct 4, 2005 | 04:53 PM
MaxObesset's Avatar
wow thats close
yea there the one piece rims i have spacer so that should clear it also where can i get longer studs from?
Old Oct 17, 2005 | 02:16 PM
Flava_24/7's Avatar
Boosted Panda
Im considering this as well, My wheels are only 18x7.5 as well and Im not sure of my offset but here ar some pics if this helps,...
Im really hoping I wont need spacers.
Old Oct 17, 2005 | 02:21 PM
Jeff92se's Avatar
I'm needing a caw
If you are that close with the stock caliper, you won't have a chance with the cobra rotor / 300z caliper.
Old Oct 17, 2005 | 02:33 PM
Flava_24/7's Avatar
Boosted Panda
So I'll need more then the 1in. that I have over the oem huh, great.
So what size spacer do you think I will need to clear?
i guess Im also going to have to go with longer studs.
Old Oct 17, 2005 | 02:58 PM
Shadow's Avatar
If you only have that 1" of space the picture shows, most likely you will need spacers. My wheels had more clearance than that, and they didn't clear the brakes.
Old Oct 17, 2005 | 03:51 PM
MaximaSE96's Avatar
Maxima Owner
whats the big deal with spacers.......who cares they are cheap and they give u a wider track anyway.....gl with brakes
Old Oct 17, 2005 | 04:21 PM
A Flood99's Avatar
i remember looking at my wheels and thinking, geez...i've got plenty of room
now with a 5mm spacer they still rub against the wheel
Old Oct 17, 2005 | 04:26 PM
Jeff92se's Avatar
I'm needing a caw
I can understand using a very thin spacer. But using a thick spacer can't be good. Just stacking spacers and using longer studs can get dangerous.
I never really understood why people go to such extremes. Especially now when there are threads that show you which wheels will clear. None of this was available when I was doing my bbk. Now, lots of oem 17"/18", G35 and 350z wheels clear no problem. And many of these wheels can be found cheap too.
Old Oct 22, 2005 | 07:45 AM
MaxObesset's Avatar
would these clear 300zx brake kit
Finish: Gun Metal
Size: 18" x 7.5"
Bolt Pattern: 5 on 100, and 5 on 4.5(114.3)
Offset: +45mm
Weight: 22.5 lbs/wheel
Center Caps Included
also which bolt pattern are maximas
Old Oct 22, 2005 | 09:20 AM
96customax's Avatar
well if they do and you want it to work then you can get spacers
Old Oct 22, 2005 | 09:30 AM
A Flood99's Avatar
Finish: Gun Metal
Size: 18" x 7.5"
Offset: +45mm
I highly doubt a 45mm offset will clear
Old Oct 22, 2005 | 10:18 AM
Shadow's Avatar
With a 45 offset, not even close to clearing. And Maximas are 5x114.3
Finish: Gun Metal
Size: 18" x 7.5"
Offset: +45mm
Old Oct 22, 2005 | 12:34 PM
MaxObesset's Avatar
so how much offset do u need to clear on 18s?
Old Oct 22, 2005 | 01:58 PM
z32drifter's Avatar
you guys are missing the point.... it's not the offset it's the wheel design. I have +45 fit, +40 fit, +34 fit .... +38 don't fit. You will need close to 2" from the mounting point (where the wheel meets the rotor) to the inside of the spoke. From what I have seen you need a wheel the is high center of has spokes that curve out to clear the caliper.
Old Oct 22, 2005 | 02:53 PM
Shadow's Avatar
It's both, a lot more +35 wheels will fit as opposed to +42, etc. And when you're buying wheels mail order, it's going to be very hard to figure out if a certain wheel fits because wheel shops hardly ever have that measurement.
Old Oct 22, 2005 | 07:36 PM
Zammo's Avatar
i Have +35 and still have 1 3/4 inches clearance
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
Serotta33
Sep 17, 2015 12:14 PM
