Car start help
Old Oct 4, 2005 | 08:56 AM
euser985's Avatar
Car start help
for the past month everytime i start my car, the RPM starts below 1, then within a quick second automatically revs itself up to like 1500 Rpm and then drops down to 1100. it does it as if it needs help from the Rev to keep the car running. and i know that for sure, because just the other day i turned it on, the engine sounded like i turned it on but within a second all the lights came on the cluster. and then i tried it again and at the same time i rev'd the engine to like 2500 and it turned on successfully. this usually happens in the morning when the car is cold and i just started it, it doesn't happen during the day when the car has already been warmed up. what can this be? please help.
Old Oct 4, 2005 | 09:10 AM
NmexMAX's Avatar
dot dot dot ...
Clean TB/IACV
Check for codes. (possible codes ECTS/CPS)
Check all intake tubing for leaks etc.
Old Oct 4, 2005 | 09:36 AM
euser985's Avatar
so your saying that the car could have trouble starting because of an uncleaned throttle body and idle air control valve?
Old Oct 4, 2005 | 09:42 AM
NmexMAX's Avatar
dot dot dot ...
As well as a sensor malfunction and possible air leaking from your intake tubing.
Old Oct 4, 2005 | 09:44 AM
euser985's Avatar
thanks for the help ill check it out ASAP
Old Oct 4, 2005 | 11:57 AM
euser985's Avatar
im trying to clean my own throttle body as it guides you on:
http://www.motorvate.ca/mvp.php/517
but im having trouble performing the step on the 4th picture. which is removing the small black rubber hose. it doesn't remove that easily.i tried it as hard as i could. please tell me how i can disconnect it.
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Stagnet04
Aug 16, 2015 11:15 PM
Trin1j23
Aug 12, 2015 08:31 PM
mrgooch
Aug 9, 2015 11:00 AM
