knock sensor and mpg
Old Oct 6, 2005 | 09:29 AM
randy021186's Avatar
What is an average mpg with a bad knock sensor?
Old Oct 6, 2005 | 09:38 AM
MDeezy's Avatar
I think they average is around 16mpg. Why?
Old Oct 6, 2005 | 09:40 AM
OH WOOOOWWW Your right ....dam u know everything!!!!!!THANKS so how much would i get if i change the KS (HP AND MPG)
every thing else on the car is fine (knock on wood)
Old Oct 6, 2005 | 09:45 AM
MDeezy's Avatar
I wish I knew everthing. . .
changing the KS will give you back what you've lost, there arent any gains. your MPG should be back close to factory like number 20city/29hwy. Power should put you back to stock numbers (assuming nothing else is wrong on the car)
Old Oct 6, 2005 | 09:59 AM
thanks ......for some reason i didn't like u because u said something i didn't like when i first joined .....but ur kool
Old Oct 6, 2005 | 10:02 AM
ThisMaxIsTight's Avatar
ummm Mdeezy is a veteran here and a friend, watch yourself newb
Old Oct 6, 2005 | 10:09 AM
i know ..he is great
Old Oct 6, 2005 | 10:33 AM
Guttermouf5150's Avatar
what is your problem with what he said? he was saying that the guy was cool. he shouldn't have to watch himself because he did not like him at first. i think he has the opinion to dislike anyone he wants. just as i dislike you.
Old Oct 6, 2005 | 12:05 PM
MDeezy's Avatar
I dont know what i may have said, but I'm always nice with everyone. Good luck with the car.
not everyone likes everyone, but I usually try not to give anyone a reason to not like me.
Old Oct 6, 2005 | 01:26 PM
Sounbwoy's Avatar
just averaged 20mpg with bad knock sensor-Atlanta trip...75 to 80mph
Old Oct 6, 2005 | 02:41 PM
95MaxRB26-DETT's Avatar
My Ks has been out according to the (engine light flash) trouble code. It seems like I've lost on some mpg, but haven't noticed any drop in take off. Seems like I've lost a little if I punch it from 35 /40 and up though..
Old Oct 6, 2005 | 04:28 PM
Umass021's Avatar
I did about 75-100 miles less to a full tank.
Old Oct 6, 2005 | 04:55 PM
konak85's Avatar
when your KS is dead, do you always get a code or ghost code?
Old Oct 6, 2005 | 05:10 PM
MDeezy's Avatar
ghost code
Old Oct 6, 2005 | 06:00 PM
gassian's Avatar
i just checked my ghost code and as i expected i got KS code...so i checked on ebay i found the part # is Nissan Part # 22060-30P00
can anyone know if this is the right one?
thanks
Old Oct 6, 2005 | 07:44 PM
goldmax's Avatar
Dumb question...What's the difference between a code and ghost code?
Old Oct 6, 2005 | 07:47 PM
sonicrunch's Avatar
ghost code does not cause a CEL
Old Oct 6, 2005 | 07:52 PM
MDeezy's Avatar
ghost code wont illuminate your check engine light, it will instead remain stored as a code in your ecu. You'll know you have the KS code either by checking for codes randomly or when ever you feel like it, or when something else goes wrong and illuminates a cell, then you'll see that code plus the KS.
Old Oct 6, 2005 | 07:59 PM
jaedaliu's Avatar
my KS has been out for about 5 months now. I just need to put the new one in. For now I'm enjoying paying bottom dollar for my 87 octane gas. I was getting around 20 mpg, mostly commute miles in semi-heavy traffic (35 min trip becoming 1 hour 20, 5 mph most of the time, lots of space in front so not much stop and go.) I stopped using the defroster, rolled down the windows, replaced my plugs, replaced my gas filter, and am now getting 25 mpg. The big thing that changed was my driving, I rarely take the engine over 2k rpm any more.
Old Oct 6, 2005 | 08:55 PM
MDeezy's Avatar
imagine how much better your gas consumption could have been with same driving and a fully functional KS
Old Oct 6, 2005 | 09:02 PM
konak85's Avatar
Originally Posted by MDeezy
ghost code
no i mean if your KS is dead, can there be no code at all?
Old Oct 6, 2005 | 09:03 PM
shqipe's Avatar
it improves the gas milage for sure but not by much, its better for your engine performance
Old Oct 6, 2005 | 09:05 PM
MDeezy's Avatar
if your KS isnt fully functional it will store a code, it just wont illuminate the check engine light. So if your ks is dead there still will be a code.
Old Oct 7, 2005 | 11:22 AM
madmega's Avatar
man listen,, i just changed my knock sensor 3 weeks ago,, what a ****ing difference,, my main concern was mpg, cause i was getting 15mpg now im back at 21,, but ive got way more horsepower, and it doesnt stutter at all.... i usually got around 116 miles half way on a full tank, now im getting 160 by half way down
Old Oct 7, 2005 | 11:44 AM
udienow's Avatar
Before when I had a bad Knock sensor, there was no CEL. After my Air Temp which was dangling around set of the CEL, i also found the KS. Ignoring it at first, i just kept resetting the ECU, but KS came back every time. At this point the most I could get was 320 miles to the tank driving normally(40%City/60%highway). One day saw a cheap new OEM KS so I bought it. Installed it bymyself. The following tank I did a test to see if MPG really improved. Used the same gas from the same station (BP 93). Sure enough I was able to drive 380 miles before empty(40%City/60%highway), on the same 16 gallons of gas that I burned.
Even now that I changed jobs, and mostly drive city miles with a heavy foot, i still can hit at least 320 on 16 gallons of gas.
So if I was you I would put in a new KS asap, as it messes up your milage per tank pretty bad.
Old Oct 7, 2005 | 11:47 AM
qbvu911's Avatar
When my KS went to lunch, average MPG(mostly highway 65mph-85mph) dropped from 27 to 16 so I switched from 93 to 87 gas. With a new KS + harness cable, the MPG went back to 26-27 and I plan to continue with 87 oct gas. Car is old (95) and cannot be a collectable one, I plan and hope it lasts for 2 more years
Old Oct 7, 2005 | 11:54 AM
NmexMAX's Avatar
dot dot dot ...
Maybe we should delete all the stickys Since hardly anyone one reads them anyway ..
Old Oct 7, 2005 | 01:20 PM
After resetting the ECU How long should you drive, before you check for the ghost code? because i check after driving 5 minutes and there is no ghost code I ask because i have the code once in a blue moon, now i get it once a week. or when i fill up...i want to be sure its my knock sensor
Old Oct 7, 2005 | 02:22 PM
97maxrob's Avatar
I've been pulling the knock sensor code for at least a few months, however my gas mileage is still very good, getting close to 30 mpg with mostly highway driving. I do notice just a bit of loss of power when flooring it, but not too bad.
Old Oct 7, 2005 | 02:24 PM
lilaclucymaxima's Avatar
Team Ramrod
damn fools
Old Oct 7, 2005 | 03:44 PM
MDeezy's Avatar
After reseting the ecu you'll have to drive about 200 miles for the ecu to run thru its cycle. Before then more than likely you wont throw any codes.
Old Oct 8, 2005 | 10:07 AM
I thought my OHM tester was broken...........well after driving i did an ohm test on the sensor and got 1900-1999 reading.....then i though it is because of the heat so i let the engine kool down ......20 minutes after that no reading.....then after that i thought the ohm tester was broken .....now this morning i got 1950 reading.....so i was like WTF , so i put my hand i touch the sensor and wiggled it alittle ....now i did the reading and i GOT 550......
so after touching the sensor it went back normal.....should i still change it or is the screw or something loose? ( i already ordered a factory sealed FOR $$$$$$$$$$70 shipped)
Old Oct 9, 2005 | 07:11 PM
ctownmax's Avatar
ive got a bad knock sensor on my 95 max... and i get like 220mi/tank...... with gas prices and having to commute back and forth to school..... this sux!
Old Oct 9, 2005 | 08:19 PM
BigLou93SE's Avatar
I have not read ONE single post from you today that isn't a stupid flame on "newbs". Remember just a few short months ago when YOU were a noob? I wish that other thread about blackmax (edit: ABOUT his ugly rims, I didn't agree with the comment) wasn't closed because I replied in there too. What are you contributing?
Old Oct 9, 2005 | 10:28 PM
97MaximaSE97's Avatar
I think my KS might be broken. My battery died to the point where the battery testers couldn't even test it. I am thinking Buena Park Nissan did it to me on purpose because I got them to give me a free tire rotation. Anyways I stop at the liqour store and when I try to start it it made the cranking noise and died. Then I went to Sears and they tested it and they really couldn't because it was soooo dead, Anyways I got a new Die Hard battery but now gas millage sucks. At 100miles I am at half a tank where as a week ago I got to 157 on when the needle reached half. Same amount of gas and everything so now I'm going to go to Garden Grove Nissan and have them check.
Old Oct 9, 2005 | 10:53 PM
i am lost is this still about me? really i try to ask good questions and use my .pdf mannual (the nissan factory book)
Old Oct 10, 2005 | 04:51 AM
BigLou93SE's Avatar
No, it's not about you. It's about the member I quoted in my reply...see the above post. Honestly, there wasn't one thread that I read yesterday where he contributed something helpful to the conversation, it was all just flaming.
Old Oct 12, 2005 | 11:01 AM
kev1031's Avatar
just changed knock sensor on 97 SE, mileage actuall went down by 3-4mpg, dunno what to do, max currently at 123k miles
Do i need to reset ECU?
Old Oct 12, 2005 | 12:01 PM
U have too reset the ecu.......i changed mines last night and i wish i had done it earlier ....12 shift is smooth
