Banging (Poping) While Steering
Old Oct 6, 2005 | 07:22 PM
NCSUpilot's Avatar
First off...I know it is not the CV joint, I have heard several of these bad, and that is not it (99% sure).
Within the last few weeks I have noticed banging while I steer. If I turn left it bangs once like every half wheel turn (about 4 solid single bangs per turn). If i go straight then make another left turn it will not bang. However, if I were to make a right turn, it would bang. It's like it needs to be reset by an opposite turn (if this makes any sense...)
Example.... Left (bang) Right (bang) Left(bang) Left (no bang)...
I noticed both gear bellows for the steering have recently broken down. Also, about a year ago I had the front strut bearings replaced because I was experiencing a single heavy bang, thought it might be serious...)
Any thoughts, similar experiences?
Old Oct 6, 2005 | 07:35 PM
Sounbwoy's Avatar
Strut Bearings?
Old Oct 6, 2005 | 09:00 PM
shqipe's Avatar
check the coil overs or if not make sure u check the shocks and the springs
Old Oct 6, 2005 | 09:11 PM
NCSUpilot's Avatar
You think the struts or springs would make a banging noise while turing?
Old Oct 6, 2005 | 09:31 PM
Stuntin' 101's Avatar
if you are not lowered, unlikely... i say its a ball joint
Old Oct 6, 2005 | 11:58 PM
Bluemax95's Avatar
Mine was doing that when my pass side a-arm bushings had gone bad. The whole arm would wobble when I turned. I replaced with the energy suspension ones and it went away. If not I would check the ball joint. hopefully its not that since acccording to the manual you have to replace the whole a arm. Ill be up that way end of this month give me a call and we can tear it apart.
Curt
Old Oct 7, 2005 | 03:09 AM
i30dvr's Avatar
Originally Posted by Sounbwoy
Strut Bearings?
yeah, i forgot to reinstall them on my car and had the exact same problem. I put them back in and it fixed it
Old Oct 7, 2005 | 08:40 AM
NCSUpilot's Avatar
Curt
Word Ba$tard. The noise started right after I replaced the wheel bearing on the front passenger side. When I took everything apart, i did not notice any problems with the ball joint, there is no slop when i jack the car up and play with the wheel....
I am not lowered, everything is stock. I had the dealer do the strut bearings...everything was good for about 6 months...like I said, this happened after I took the whole assembly apart...
Signed,
At a loss...
Old Oct 10, 2005 | 12:40 PM
NCSUpilot's Avatar
Well, over the weekend, the noise decided to take a "break". I have not noticed the noise at all...either something gave way, or the problem might not be that serious.
Old Oct 10, 2005 | 12:42 PM
GodStrength
why the hell cant i post a new thread or anything, man i gotta change the water pump in my 96 maxima and the damn crank shafter damper bolt dont wanna come off, i done tried lettin the engine pop it off on its own with a home made breaker bar, and nothing wants to take it off, i heated it with a torch and still nothing man. !!!!!!!
Old Oct 10, 2005 | 01:03 PM
99SEL4ME's Avatar
Poping?????
Old Oct 10, 2005 | 01:10 PM
95MaxRB26-DETT's Avatar
My 95 "clicks" when I turn or "pops" when I turn, but haven't had it checked out.
Old Oct 10, 2005 | 01:12 PM
I think you got to make 15 posts to make a thread, you shouldn't jump into someone elses to ask questions. Thats very rude.
Old Oct 10, 2005 | 02:42 PM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
not only that, his post was as well
Old Oct 10, 2005 | 03:09 PM
DrTySOUFMaX23's Avatar
could be ur control arms bushing goin out!! mine used to pop when i turned the steering wheel but since i put new ones in it aint doin it no more..
Old Oct 10, 2005 | 05:05 PM
NCSUpilot's Avatar
The control arm bushing...where is that exactly, and how would I be able to check that?
Old Oct 10, 2005 | 05:08 PM
NCSUpilot's Avatar
That is what I have heard, when Ive heard people's CV joints are bad...might take a look at that.
Old Oct 10, 2005 | 08:46 PM
if you cut you wheel all the way, and drive foward, and you hear " click.. click.. click.. click.. " its your axle (cv joint)
if while your driving , and go over bumbs or dips, and you hear a cluck once in a while .. its most likely a ball joint.
Old Oct 10, 2005 | 08:53 PM
It's that one.. It's when I turn all the way. Exactley.. click, click, click. Thanks for the heads up
Old Oct 10, 2005 | 09:06 PM
DR-Max's Avatar
Check your steering bellows, both sides. If they are torn and your steering have been working all this time, you probably lost all the grease. Your just moments away from loosing your rack n pinion.
Old Oct 10, 2005 | 09:34 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
I had this noise when my PS fluid was low.
Old Oct 10, 2005 | 09:43 PM
dabooki's Avatar
sounds like the axle???? when mine got bad it was thumping all the time even going straight except when accellarating
dabooki's Avatar
usually you can see if there is a tear in the rubber booty
Old Oct 10, 2005 | 09:47 PM
if your refering to your axles, thats either becuase you didnt notice them going bad at first, or you rarely make tight turns.. cv joints wear, they dont just all of a sudden go bad overnite. it take a while for them to get as bad as your describing, but when they are REALLY worn, yes they will do that
Old Oct 11, 2005 | 12:06 PM
u would have to take the whole thing apart, meaning: take out tires, brake system,shocks..if u not sure what u doin u really have to take it somewhere to get it looked at and have them do it.. i took mine to the nissan dealership! it's really nothing bad just dont wait too long for u to make actions bout it..
Old Oct 11, 2005 | 08:30 PM
NCSUpilot's Avatar
Ok thanks....like I said the noise has pretty much gone away for now... I'll see what happens.
Old Oct 11, 2005 | 08:32 PM
NCSUpilot's Avatar
This is my feeling of what it probably is...The bellows are torn, it feels like there is still some grease in there, but probably not enough, coupled with the road grime, that's probably it...Ill probably shoot some more grease in there to help a little. I really don't want to replace the rack and pinion, sounds like a hard job and expensive.
Fbana41
Aug 29, 2016 12:18 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
