NEED HELP ASAP in locating EGRC Solenoid Valve
Old Oct 7, 2005 | 02:59 PM
S Cranaw's Avatar
CEL came on and I pulled codes for the EGRC Solenoid Valve. Does anyone have pics or a diagram pointing out this part. And how hard is it to change for someone who is moderately good with cars. Thanks.
-Steve
Old Oct 8, 2005 | 09:01 AM
S Cranaw's Avatar
nothing guys?................. bump
Old Oct 8, 2005 | 09:07 AM
Nismo3112's Avatar
Custom User Title
driver side of the engine, near the front valve cover, it has a green connector on it with a couple vacuum hoses going to it.
Old Oct 8, 2005 | 09:47 AM
RA030726's Avatar
I'm nutty for Nissans
its on the back side of the block (tranny side) near the fuel pressure regulator and knock sensor. the solenoid is green with a 2 wire plug and 3 vacuum hoses. its just about impossible to remove. the nut holding it on is underneath. i had a hell if a time with it.
Old Oct 8, 2005 | 10:16 AM
Bobo's Avatar
Supposedly if you put your hand under the EGR valve and push up on it, it is good to go if it moves and has some flex in it. I read this somewhere. I think I may have to clean my EGR valve and plenum as my NOx levels were somewhat elevated in my recent emissions test. I passed and am good to go for 2 more years, so I may just leave it alone for the time being as I don't believe the EGR system affects the vehicle's operating performance. Consequently your problem may lie somewhere else.
Old Oct 8, 2005 | 01:37 PM
ThurzNite's Avatar
I used an angled closed wrench to get it off, no problem. The FSM has a proceedure to check if it's functioning. Lemme kno if u need the FSM.
Jae
Old Oct 20, 2005 | 06:19 PM
S Cranaw's Avatar
Thanks for the input guys.
-Steve
Old Oct 21, 2005 | 05:32 AM
knight71's Avatar
-Steve
Location of Egr related stuff:
http://photobucket.com/albums/v158/e...s_location.jpg
Old Sep 8, 2006 | 05:57 PM
maximaman10's Avatar
I had to take off the throttle body to get to my EGR valve. It did make it easer to clean the throttle body and the intake.
t6378tp
Sep 29, 2018 04:27 PM
homeofbacon
Sep 23, 2015 07:17 PM
chernandez1278
Sep 16, 2015 01:18 PM
