Installed Tokico blues, car sits higher WTF!
Old Oct 12, 2005 | 06:11 AM
tucker's Avatar
Gents,
'96 GLE: Supplied the dealer with a full set of Tok blues and had a 4-wheel alignment last week. The car seems to sit higher. Didn't think struts would alter height. Is this an illusion or do the springs need to settle? Thanks...
Old Oct 12, 2005 | 06:52 AM
maxgtr2000's Avatar
KH3 by popular demand
Sometimes when I jack my car up it sits higher for a little while. But then again seeing all these slammed maxs with no wheel gap on here can make anything look like a 4x4. Also blown struts will make the car sit lower because it is no longer supporting as much vehicle weight.
Old Oct 12, 2005 | 06:54 AM
96blackmaxSE's Avatar
boost me.....
Originally Posted by tucker
Gents,
what kind of springs do you have on there?
Old Oct 12, 2005 | 07:17 AM
tavarish's Avatar
fwd gone rwd cr00
the springs most likely need to settle.
Old Oct 12, 2005 | 07:21 AM
mendon99's Avatar
tastey wheat
give it a week or 2, then post results.
Old Oct 12, 2005 | 07:22 AM
matty's Avatar
If your didnt change the springs, the car isnt going to sit any lower...its probably sitting the same height it did with the stock stuff on because it seems like all you changed were the struts
-matt
Old Oct 12, 2005 | 09:26 AM
tucker's Avatar
Nope, everything is stock except the struts. I thought the struts just did the dampening. The original struts were leaking oil. Car is definately sitting higher.
Old Oct 12, 2005 | 10:35 AM
maxgtr2000's Avatar
That's normal then. Blown struts sag, ever seen a max with blown rears, definitely sag. Fronts do the same too. Once they are replaced it's back to 4 wheeling.
Old Oct 12, 2005 | 10:48 AM
d00df00d's Avatar
Old enuf to pick his own gears
^^ If your old struts were blown, then you'll definitely notice the car sitting higher with the new ones.
Also, the Tokico Blues will be a little firmer than OEM to be able to cope at least somewhat with aftermarket springs, so they're probably supporting the springs a little more than the OEM ones did.
GLE springs are SUPER-soft... you'll notice differences among struts a lot more because of that.
Old Oct 12, 2005 | 10:55 AM
gtr_rider's Avatar
192.168.1.1
Replacing blown shocks will most definately restore ride height to factory spec if the factory shocks were blown for a long period of time and had time to sag.
Old Oct 12, 2005 | 11:04 AM
naijai's Avatar
basically the tokico blues are oem struts for the car so yu just replaced yur struts with a new set so yu still factory dude//get a set of tokico springs and yull be straight
Lakersallday24
Jun 16, 2019 01:35 AM
Finkle
Sep 27, 2015 09:53 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
doobadoo
Aug 15, 2015 06:43 PM
acw
Aug 7, 2015 04:20 PM
