auto climate control pissin me off
Old Oct 14, 2005 | 10:54 PM
MidniteMaxSE's Avatar
first off..before modding my climate control..(leds) i noticed that between 65 and 84 degrees it is cold..the only way to make it warm is to put it on 85 which is sometimes too hot?anyone else have this problem
now that ive decided to put the leds in one of the bulbs only lights up when the ignition is switched on and the lights are all off and when i turn the lights on it goes out...the others work normal..i cant figure out the problem...it seems to be wired right!...
any insight would help...thanks
Old Oct 15, 2005 | 04:35 AM
Mxrider52's Avatar
I support for what?
I would have to say miswired because if it wasnt then they wouldnt go off when lights were turned on
Old Oct 15, 2005 | 06:21 AM
njmaxseltd's Avatar
Your climate control isn't working correctly. Might be a faulty sensor causing it. You might want Nissan to trouble shoot the system or see if you can find out how to get into the system to trouble shoot it yourself.
Old Oct 15, 2005 | 07:55 AM
yea sounds like a trip to nissan on monday..btw..that plastic hose on the back of the climate control that leads to the little vent wasnt pluged in ..would that make a difference?.i would check but i got the whole thing taken apart right now.
and i switched one of the working leeds with the one thats being retarted and i got the same result
Old Oct 15, 2005 | 07:57 AM
njmaxseltd's Avatar
That plastic hose is used to route cabin air to a temp sensor. That could very well be causing your temperature control issue.
Old Oct 15, 2005 | 08:56 AM
Jatan's Avatar
When you put it on 85 does the fan speed go to full (4)? When it's under 85 does the fan speed stay between the speeds of 1-3? Might be: http://forums.maxima.org/showpost.ph...2&postcount=31
Old Oct 15, 2005 | 04:44 PM
it works normal on 85...i just put it back together and plugged in the hose...same thing!
Old Oct 15, 2005 | 05:31 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
Take the Digital Climate contorl a part, and then put it back together, It happened to me before and by doing that it got fixed. Don't ask me how?
Old Oct 15, 2005 | 05:44 PM
kbmaxima's Avatar
+1 on the taking it apart and putting it together again. Some connections may not be seated well and causing your mishap. Also, wire up the led's to a constant 12V source. I think I ran a wire down to the cig lighter, or security light, i forget.
Old Oct 16, 2005 | 03:22 PM
i didnt do it that way..i used the original thing that holds the bulbs and ran the lead through it like the factory one and kept the resistor on the inside...as far as the climate problem ..i took it apart a few times....same thing!
gavin68
Sep 18, 2021 12:36 PM
tseng1023
Oct 15, 2015 08:30 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
dshinn
Sep 26, 2015 08:07 PM
