Where is water leaking in? (Water on passenger floor)
Old Oct 16, 2005 | 08:27 AM
paul2112's Avatar
After a week of heavy rains, I just realized my back floor is soaked on the passenger's side. There is dampness under the seat as well, and my trunk is wet. Where is the leak? In the trunk weatherstripping? Back window? Or a hole in the floorboard?
Old Oct 16, 2005 | 09:53 AM
njmaxseltd's Avatar
Trunk leaks almost always come from the tail lights.
Not sure about the back floor....
Old Oct 16, 2005 | 10:05 AM
cnenov's Avatar
check the plugs under the back seats.
Old Oct 16, 2005 | 10:26 AM
2 Da Max's Avatar
happened to my boys tl as well, its one of the lines inside the car thats suppose to carry it out. ill get more info later, his car is at the dealership with that same problem
Old Oct 16, 2005 | 11:23 AM
InsneDrmr's Avatar
I have the same problem. But in my car is flowing in from the back right seat belt. It pours out all over the back seat and the cushion part is soaked. I tried taking it apart, and resealing everything thats in there but it didnt help. Im not quite sure where the problem is.
Old Oct 16, 2005 | 12:14 PM
alpicone's Avatar
For the trunk check the taillights. It usually leaks from there.
Also do you have a sunroof?
Old Oct 16, 2005 | 04:37 PM
InsneDrmr's Avatar
I do have a sunroof but all my seals are good. No problems there.
Old Oct 16, 2005 | 05:40 PM
alpicone's Avatar
Its not the seals. Water gets past the seals and there is a channel on all sides of the sunroof that the water flows into and then drains out. There are drains on all four ends of the car that the water flows out of. I know it is a common problem with the 3rd generations that they accumulate dirt up there and the drains get plugged and it leaks into the car. It is common with the 3G because they are older so by now they are most prob plugged unless they were cleaned out. Its possible you have the same prob on yours.
Open your sunroof and pour some water into the channels and see if it flows out. Put a lot of water to make sure. If it starts to pool up then....
Old Oct 17, 2005 | 01:29 PM
paul2112's Avatar
2 Da Max, I'm interested to hear what happened with your buddy's car. LEt me know.
BTW. My windows or sunroof show absolutely no sign of leaking. Initially I thought there was a hole in my floorboard because the water seemed to have came out of nowhere. But now that I've heard about these drains, I'll look into that. But I have no clue where they're located.
Old Oct 17, 2005 | 01:43 PM
njmodi's Avatar
Do I get a tax break?
This man speaks the truth. The other possibility (if the drain holes are not clogged) is that the tubing might have come seperated. There is a T-fitting under the antenna assembly. The sunroof drain and antenna drain connect at the T and drain out together there... make sure that plumbing is all in place and not clogged/etc.
Old Oct 17, 2005 | 02:02 PM
Jatan's Avatar
captchaos
Mar 15, 2016 12:18 PM
Excalibur23
Oct 13, 2015 04:33 PM
The Wizard
24
Oct 1, 2015 08:47 PM
RWCreative
Sep 21, 2015 11:01 AM
Hdnseek
Sep 9, 2015 05:55 AM
