How can i enable my check engine light
Old Oct 16, 2005 | 08:43 PM
shqipe's Avatar
i bought a maxima 97 with a 98 engine. I can pull the codes out of the ecm with a code reader, but i can't seem to find a way to enable the check engine light.
Whoever haded before it seemed to have desabled the check engine light.
If someone has some info please inform.
Thanks in advance.
Old Oct 16, 2005 | 08:49 PM
I30tMikeD's Avatar
For whatever reason, sometimes the CEL won't appear even when codes are present.
What codes are you getting?
Have you tried checking them with the ECU screw? The CEL should definately light up when doing that process. If it doesn't then I would agree that the light itself is not working. But just the CEL not comming on when codes are present doesn't mean the light doesn't work
Old Oct 16, 2005 | 10:02 PM
drew76924's Avatar
cel check stickey ???
is the light burned out
Old Oct 16, 2005 | 10:29 PM
DcMaN's Avatar
turn the car to the ON POS the one right before start all the dummy lights should come on including the check engine light. If not they removed the bulb or it is burnt out.
Old Oct 17, 2005 | 08:52 AM
shqipe's Avatar
thanks guys.
I think you right. When i turn the key to on poisition
all the lights come on but the check engine light.
The light probably gone.
Old Oct 17, 2005 | 09:14 AM
MaximaSE96's Avatar
Maxima Owner
time to rip the cluster out and change the bulb
Old Oct 17, 2005 | 09:54 AM
sunten1
I think the is the same problem with my car, what bulb do i need???
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
