Lost 60-70 miles per tank after O2 and Knock sensor
Old Oct 17, 2005 | 05:23 PM
kev1031's Avatar
did major maintenance and changed two O2 sensor and knock sensor, now the miles per tank went from 300 miles to barely 240 miles????
What can cause the degrade performance on mpg? It just don't make sense to me. Most ppl claimed to gain mpg and acceleration, but my car got worse...
Old Oct 17, 2005 | 06:08 PM
NmexMAX's Avatar
dot dot dot ...
Did you run the tank completely empty or ... MPG's are a better indicator.
Old Oct 17, 2005 | 06:10 PM
Loe max's Avatar
Yikes thats only about 13mpg
Old Oct 17, 2005 | 06:13 PM
kev1031's Avatar
yea, empty the tank and got 240 miles (w/same driving style and hwy/local mix)
Old Oct 17, 2005 | 06:15 PM
NmexMAX's Avatar
dot dot dot ...
So you ran out of gas?
I hate you Loe ... Where the hell you get all the bank to buy so many cars
Old Oct 17, 2005 | 06:16 PM
siballiance's Avatar
where did u get ur knock sensor and o2 sensor?
Old Oct 17, 2005 | 06:17 PM
qbvu911's Avatar
Read the ECU and make sure that the knock sensor is still OK.
Old Oct 17, 2005 | 06:20 PM
Loe max's Avatar
NmexMAX
Old Oct 17, 2005 | 06:32 PM
kev1031's Avatar
knock sensor (ebay, referred by some dude here)
Bosch O2 (autozone)
Check after 1st week, code still exist, 2nd week again, it was gone..how funny
Reset ECU (turn screw clockwise then counter clockwise x 2), correct me if i'm wrong
The car will pulls a bit harder rigth after reset, but my 60 miles are gone now...any comments
even with new knock sensor went bad again, but before all the work, i used to get 300 miles, can't justified with all these new parts.
Old Oct 17, 2005 | 06:37 PM
THT's Avatar
THT
Throbbing member
Did you cleanly install the O2 sensor? I ask b/c if you get the anti-seize on the sensor, it can cause it to malfunction. Any codes?
Old Oct 17, 2005 | 07:59 PM
goldtooth's Avatar
slight gas leak, has to be fo sho
Old Oct 17, 2005 | 10:24 PM
machinehead's Avatar
$3 a gallon....someone is stealing yo gas!
Old Oct 18, 2005 | 10:32 AM
the_3d_man's Avatar
lol... do you live in the ghetto?
Old Oct 18, 2005 | 10:57 AM
ziya20's Avatar
check the tire pressure and put a injector cleaner.
Old Oct 18, 2005 | 11:34 AM
NmexMAX's Avatar
dot dot dot ...
What about the other 5?
Old Oct 18, 2005 | 04:11 PM
THT's Avatar
THT
Throbbing member
Since when do we have six injectors?
Old Oct 19, 2005 | 08:37 AM
MaxKlinger's Avatar
Time to rebuild the carburator.
Seriously, you can't go by the number of miles per tank, you have to calculate your MPG. You also have to run through a couple of tanks...you could have had just a bad batch of gas, crappy weather, more traffic, etc. Give it some time. A new o2 and KS should make things better, not worse.
Old Oct 19, 2005 | 05:38 PM
kev1031's Avatar
I thought the O2 and knock sensor installed correctly, I will scan for codes after another week of driving. If O2 fails, then THT may be right about O2 failure, and that's how I see it can get MPG worse.
Guys remember, with everything that needs to be clean or change mentioned above, none of it was done and I used to get average of 300/tank so just changing O2/Knock sensor it should either stay the same or better, not down to 50miles or more.
How long does it take for ECU to re-adjust and fully maximize setting with the new parts after resetting it?
CorollaULEV
30
Aug 9, 2021 08:11 PM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
Slamrod
Sep 3, 2015 07:38 PM
maxinout93
Aug 20, 2015 02:17 AM
