Iacv
Old Oct 20, 2005 | 12:20 PM
LOST's Avatar
Iacv
can some one tell me were this is and how to clean. my max wont stay running, idle drops way low and stalls. also has any one cut the speed sensor on the ecu, any issues with that. thanks LOST
Old Oct 20, 2005 | 12:28 PM
pawnstar12's Avatar
BUY MY CARS PLEASE!!!
attached to your tb
Old Oct 20, 2005 | 12:33 PM
Fr33way™'s Avatar
Wild for Width
Stickies....
Old Oct 20, 2005 | 12:35 PM
Bobo's Avatar
It will be difficult to clean it given that it seems that you are blind. There is an extensive write-up in the 2nd post in the How To sticky!
Get with the program.
Old Oct 20, 2005 | 12:36 PM
LOST's Avatar
i read thur the stickeys i didnt see any thing, if you post a link i wont bother you any more
Old Oct 20, 2005 | 12:37 PM
LOST's Avatar
**** all you guys and your damn stickeys. you all had to start some where to
Tatanko's Avatar
Bacon Lover
On my website, as well as vqpower.com...there are write-ups on how to get rid of the speed limiter, if that's what you're referring to by "speed sensor."
Good way to get banned. Calm down, and wait more than 30 seconds for a response.
Old Oct 20, 2005 | 12:38 PM
LOST's Avatar
yes i did that cut the pink and blue wire wondering if any driveabilty issues i printed the sheet that said there were none but i am a 5 speed
Old Oct 20, 2005 | 12:39 PM
Tatanko's Avatar
Bacon Lover
If you do it properly, there should be none.
Bobo's Avatar
That is right! We started with the stickies and the FAQs, so like I said, get with the program!
Old Oct 21, 2005 | 09:01 AM
LOST's Avatar
Ok guys, I read the stickeys and cleand the iacv. car doesn't want to stall, but the rpms still drop to 300-400 rpms. I checked the codes again today and they are as follows 0104, 0304. i know by the stickeeys that 0304 is a knock sensor. My ? is can that cause a drop in rpms. Sorry for my atitude yesterday was having a bad day. Thanks LOST
Old Oct 21, 2005 | 09:10 AM
Bobo's Avatar
0104 has to do with a vehicle speed sensor. Resolve that problem, reset the ECU and see if 0304 comes back.
Refer to section 6-15 in the Haynes manual for how to check the VSS. However, I question what that code has to do with you low idle.
Old Oct 21, 2005 | 09:28 AM
LOST's Avatar
i cant resolve that problem i cut the wire to make the car run 140 mph thanks
Old Oct 21, 2005 | 10:08 AM
Bobo's Avatar
Maybe you screwed up the IACV when you cleaned it. I suggest you drive the car for awhile and the idle may return to normal. I had a similar problem with elevated idle after cleaning my throttle body this week and it went away the next day, returning to normal idle once again.
schmellyfart
Sep 25, 2015 04:47 PM
junito1
Sep 23, 2015 12:14 PM
bumpypickle
Sep 20, 2015 08:22 AM
Jamie Bowen
Sep 6, 2015 09:59 PM
nbstriker10
Sep 4, 2015 04:26 PM
