Bled the brakes today and WOW what a difference!!!
Old Oct 20, 2005 | 06:47 PM
f550maranello2's Avatar
Just wanted to tell everyone that when i was bored today i decided to bleed the front brakes... and the result was awesome!!! The pedal is much stiffer now and the car stops on a dime...
Old Oct 20, 2005 | 06:51 PM
Nissan 6's Avatar
which process did you use to bleed them in
Old Oct 20, 2005 | 06:55 PM
kcryan's Avatar
alright whats the easiest method, you talked me into it.
Old Oct 20, 2005 | 07:02 PM
mtrai760's Avatar
'Trynna' is not a word
Umm, your supposed to stop from the right rear, not just do the fronts...
Old Oct 20, 2005 | 07:20 PM
goldtooth's Avatar
Originally Posted by mtrai760
Umm, your supposed to Start from the right rear, not just do the fronts...
Thats exactly what I was thinking..lol.
i30ds's Avatar
Armed and Dangerous
See what even half @ssed maintenance can do.
Old Oct 20, 2005 | 07:24 PM
2 Da Max's Avatar
lol
im too lazy to do mine..
but i guess 80k miles passed so i should do it anyways
Old Oct 20, 2005 | 09:02 PM
FishyMan's Avatar
i heard it was supposed to be farthest away and in an X way or something..
Old Oct 20, 2005 | 11:14 PM
goldtooth's Avatar
from farthest to closest to the (master cylinder?,(its 1:22am not sure if im right) so you would start at the rear passenger, rear driver, front passenger, front driver.
Old Oct 20, 2005 | 11:34 PM
mtrai760's Avatar
Yeah, they give half a$$ed results.
Old Oct 21, 2005 | 04:22 AM
lilaclucymaxima's Avatar
Team Ramrod
I just changed 3 of my spark plugs and WOW what a difference!!!
Old Oct 21, 2005 | 04:26 AM
mad-max98's Avatar
it's right rear lt front lt rear then rt front
Old Oct 21, 2005 | 09:57 AM
tomservo291's Avatar
Farthest from the master cylinder, working towards it...
pass. rear
driver rear
pass. front
driver front
You want to get out all the dirty/moisturized fluid at the ends first of course. If you did the front first, the front half of your car would have clean brake fluid, then when you go to do the rear, you're going to be using the clean brake fluid to push the rear out, which will make it mix and you will end up wasting a lot of fluid (since you're mixing you will need to keep using more and more until you finally get out all the dirty/mixed fluid) and not end up with as clean fluid in the end.
This way, doing the rear first, you are ensured the rear portion of the brake lines have clean fluid in them, then when you bleed the front brakes that rear brake fluid isnt moving anywhere and you're just pushing out the fluid left in the front of the car.
Old Oct 21, 2005 | 10:03 AM
pass. rear
driver rear
pass. front
driver front
Yea i started 2 days ago doing it the way stated above but then yesterday i just did the fronts again...just because i wanted to be sure all the fluid was clean. but even yesterday when i turned the bleeder screw tons of air came out before the fluid...
Old Oct 21, 2005 | 10:45 AM
Stephen Max's Avatar
Okay, here's what the FSM says about the order in which to bleed the brakes:
Old Oct 22, 2005 | 02:55 PM
SiliconStyleS9's Avatar
how much would it cost to go to a Nissan shop and have them do this for you?
Old Nov 8, 2005 | 07:58 PM
mad-max98's Avatar
the way i stated is way stated in the mannual
spazma7ik
Jan 12, 2017 09:38 PM
BkGreen97
Apr 2, 2016 05:47 AM
bbsitum
Sep 11, 2015 04:55 PM
beerman1378
Sep 8, 2015 02:19 PM
