Plugs
Old May 31, 2001 | 01:16 PM
Maxfreak
Just wondering about regular copper spark plugs. I know about NGK plat., but I have also heard that copper is a better conductor than platinum. Just wondering. Has anyone put these plugs on?
Old May 31, 2001 | 01:40 PM
deezo's Avatar
Stick with the NGK Plats.
Old May 31, 2001 | 01:42 PM
Maxfreak
Why? Besdides there from the factory.
Old May 31, 2001 | 01:48 PM
bill99gxe's Avatar
Evil Administrator - "The Problem"
This might be helpful. Couple of good links, especially by Jeff92se. Searched for "copper spark plug"
http://forums.maxima.org/search.php?...der=descending
Old May 31, 2001 | 01:53 PM
deezo's Avatar
It's just that the Bosch plugs don't have the umpf like the NGK's have at the low end. I can notice the difference. My next go around will be the NGK's again.
Old May 31, 2001 | 02:02 PM
Maxfreak
O.K. I get that, but those are platinum were talking aboot. What's wrong with copper?
Old May 31, 2001 | 02:06 PM
bill99gxe's Avatar
Look at the link I gave you and you shall find out.
Searching is the key.
Old May 31, 2001 | 02:10 PM
Maxfreak
Done that. It seems the copper ones would be better for performance, right? And at 2.50 a plug that's a he11 of alot cheaper than plat's, even if you do have to replace them more.
Old May 31, 2001 | 02:19 PM
zaebis
not only that. in high refined engine such as Max copper will most likely cause your engine to hesitate or even miss. ig you like smooth engine then PFR5G is the way to go, if you like smooth and powerful engine PFR6G is the way to go. anything else (especially holofire, splitfire, rapidfire and the like) is asking for holes in your pistons. those will do fine however in chevy cavalier.
Old May 31, 2001 | 02:44 PM
cvannote's Avatar
I went to the NGK iridium's. Very hard to find where I am in Denver, but I found a place, Monarch Products, who were referred to me by the people at NGK when I called. I got them over the phone for $6.40 each! I really noticed the difference over the factory NGK's. Their number is 1-888-800-9629
Old May 31, 2001 | 02:53 PM
bill99gxe's Avatar
Theoretically, that's true. And theoretically, the interval of replacement would have to be 30k instead of 60k. Having not tried copper plugs in the VQ, I'll not speculate.
It's probably worth a shot to see how they do. I doubt any damage will occur......
Old May 31, 2001 | 02:59 PM
Jeff92se's Avatar
I'm needing a caw
Isn't the interval for copper plugs like 15k?? He would have to spend 4 x $2.50 plus the labor to change them 4 times. Still worth it?
Old May 31, 2001 | 03:11 PM
seanqlee
Are the NGK iridiums the ones that people are recommeding to buy? I noticed there are 3 types of NGK platinums: hot, cold, standard. Are the iridiums platinum? I'm a newbie at this.... I need to get a set of new plugs too. help!
Old May 31, 2001 | 03:30 PM
deezo's Avatar
Yes.
Old May 31, 2001 | 04:26 PM
vmok's Avatar
bill99gxe---> can you paraphrase what's on the other side of that link that jeff has on tt.net here? i don't have a logon for twinturbo.net. thanks.
-V
Old May 31, 2001 | 09:29 PM
max808's Avatar
Plat vs. Iridium?
Any ideas on the comparison.
TKHanson
Nov 24, 2018 01:39 AM
trsandrew
Apr 8, 2016 06:45 PM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
