need help ASAP
Old Oct 25, 2005 | 11:08 AM
S103100F's Avatar
need help ASAP
ok i'll start with i get 115 miles on 10gal what can i do i dont know what to do
Old Oct 25, 2005 | 11:19 AM
LUVINIT's Avatar
fuel filter,plugs,O2?? for starts...what kinda gas 87/91??
Old Oct 25, 2005 | 11:39 AM
Jatan's Avatar
Do a tune up and get new front oxygen sensors (call up oxygensensors.com and mention maxima.org for 10% discount - pay with a CC)
Old Oct 25, 2005 | 11:46 AM
sonicrunch's Avatar
knock sensor
end of story
read the stickies
Old Oct 25, 2005 | 11:50 AM
ThisMaxIsTight's Avatar
yea seriously ... read the stickies ... this guy is wack ... SPEAK ENGLISH !!
Old Oct 25, 2005 | 11:51 AM
Jatan's Avatar
Originally Posted by sonicrunch
knock sensor
end of story
read the stickies
KS alone won't kill the gas mileage by that much
Old Oct 25, 2005 | 12:25 PM
Bobo's Avatar
Do you have a CEL? When was the last time you: checked the tire pressure, changed the oil and filter, replaced the fuel filter, air filter, PCV valve, spark plugs, used fuel injector cleaner, eg. Chevron Techron, etc. etc.
Old Oct 25, 2005 | 12:28 PM
njmodi's Avatar
Do I get a tax break?
Maybe your rear brakes are binding too... are you sure you don't have a fuel leak?
Old Oct 25, 2005 | 08:09 PM
S103100F's Avatar
no cel
new oil almost brand new air filter pcv valve done spark plugs i got only 10k miles on them (njk)
Old Oct 25, 2005 | 08:10 PM
S103100F's Avatar
ye and i have brand new ks
Old Oct 25, 2005 | 08:31 PM
NmexMAX's Avatar
dot dot dot ...
What about the other suggestions? You failed to anwser them ...
Old Oct 25, 2005 | 08:42 PM
99grnmaxgxe's Avatar
Yeah...Stickies would help. Do a tune-up, and check your tire pressure.
Old Oct 26, 2005 | 07:56 AM
S103100F's Avatar
everything was done still having same problem
Old Oct 26, 2005 | 07:58 AM
NmexMAX's Avatar
dot dot dot ...
Well if everything was done, and you do not have any codes, then I suggest you re-calculate your MPG.
Old Oct 26, 2005 | 08:30 AM
lilaclucymaxima's Avatar
Team Ramrod
What do you mean by "everything"?
Old Oct 26, 2005 | 11:04 AM
S103100F's Avatar
air filter-done
fuel filter-done
spark plugs-done
ks-done
PCV valve-done
what other things i should check/change
Old Oct 26, 2005 | 11:16 AM
Team Ramrod
air filter-done
fuel filter-done
spark plugs-done
ks-done
PCV valve-done
Oil change? Try cleaning your throttle body and check for any hidden codes (oxygen sensors in particular).
Old Oct 26, 2005 | 12:23 PM
Jatan's Avatar
http://forums.maxima.org/showpost.ph...6&postcount=38
Old Oct 26, 2005 | 03:19 PM
jvienneau's Avatar
None of those things are going to get you 11.5MPG. What kind of driving are you doing? Something has to be seriously wrong if it's not all bumper to bumper driving. Like a leaking injector which should set a code.
Old Oct 26, 2005 | 03:32 PM
NmexMAX's Avatar
dot dot dot ...
Leaky injector wont 'leave' a code
Old Oct 26, 2005 | 07:07 PM
S103100F's Avatar
so bad/leacky injector wont triger cel?
Old Oct 26, 2005 | 07:10 PM
S103100F's Avatar
how about spark plugs i know i have ngk they usually last over 60k can they make such a difference?
another thing when i am driving over 50 my rpm dont go down they stay like at 3k-4k is that normal?
Old Oct 26, 2005 | 08:48 PM
BK1's Avatar
BK1
Hello
There are many factors to consider when it comes to MPG. General tune of car, tire pressure, hard acceleration (are you racing people from the light), high speeds (are you going over 70), extra cargo (do you have a big stereo or transport alot of people), what type of gas you use, are you driving into wind all the time, driving with the windows open?, heavier wheels.
Old Oct 27, 2005 | 05:23 AM
S103100F's Avatar
i am gonna start with spark plugs and gonna work my way up i hope i get this thing fixed
Old Oct 27, 2005 | 01:28 PM
NmexMAX's Avatar
dot dot dot ...
Is your OD on or off . ..
Old Oct 27, 2005 | 02:32 PM
S103100F's Avatar
is on why that makes a difference?
Old Oct 27, 2005 | 02:36 PM
NmexMAX's Avatar
dot dot dot ...
If it's off, it won shift into 4th, could be your RPM deal ...
Old Oct 27, 2005 | 03:54 PM
S103100F's Avatar
what do you mean RPM deal?
Old Oct 27, 2005 | 04:00 PM
NmexMAX's Avatar
dot dot dot ...
maxfever1987
Nov 19, 2016 08:01 PM
NewMax03
Oct 29, 2015 07:44 PM
MaximaRaj
27
Oct 2, 2015 07:31 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
chernandez1278
Sep 16, 2015 01:18 PM
