O2 Rear / Clean?
Since SeaFoam is suppost to be safe on O2 sensors, couldn't you just soak it in Seafoam for a bit? Rear O2 sensor doesn't effect performance btw so do whatever you please with this sensor, its only there to monitor the cat and you dont have a DTC for Catalyst inefficiency. The only time the ECU will rely on this sensor is when one of the two front sensors is out-of-range.
Originally Posted by clive
Is the rear sensor same as the front 2?
If so it occurs to me that I should swap my nonworking right front bank sensor for the one at the rear of the CAT...
Huttig2009
Sep 25, 2015 03:31 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
